you guys have a lot of confidence in 26+ year old engines, this engine I have was supposed to be a 1 owner 120k motor, so its a lottery finding that "good one", not sure where you
pick them up for a slab cause all wreckers want $700 for a motor.
I got mine for $150, it was running in a vl and pretty much ready to go. I have just finished rebuilding it, in
hindsight I should have just shimmed the oil pump and dropped a twin cam head on
Sent from my iPhone using SAU Community mobile app
Yes we do :D
pulled a piston out today, measured it and it has 21thou of wear on the top side plus 1.5thou on the bore, so that makes about 23thou piston to bore clearance,
why would someone sell a good R31 for $400 if it had a good motor in it? I think I must be in the wrong state, need to move down south for the goods..
23 thou is massive, I've never seen a running engine with slop any where near that! Mine had over 300,000 on the clock and I only rebuilt it for piece of mind and so I could ceramic coat everything
Edited by Glynn82
If going forged, is it ok to go 88mm pistons if limiting power to 350kw's or will the block crack? would be extra torque for free
thinking about wisecos with the coated skirts, theres a few threads with mention of
tightening the piston to wall clearance down to as small as 2thou without issues, so maybe 2.5-3thou for a street application might be doable and the slap might be very
minimal. Using E85 the piston would be running cooler than 98, and not being on a track the pistons would have chance to cool down between floggings as you cant be drive flat
out on the street anyway or even at the drags for long.
Edited by AngryRB
Anything under 350 and I'd be using stock replacement with a piston to bore clearance of 1.3 to 2 thou. Remember it's the tune that kills engines.
I would seriously be listening to Simon-s14 though, he has had great success with rb30s
Edited by Glynn82
You mean lower cylinder temps so less thermal expansion of the piston? I'm just curious, never built an engine or anything i just like knowing how things work.
Yeah that was the idea :thumbsup:
I've had a long day and not used to doing them so a little slower then normal on details tonight
The idea of the lower temp thermostat was to keep head temps down to try and reduce hot spots, I also found places where air could get trapped in the head water pocket and modified it to let it out
I wouldn't go straight to 88mm but I wouldn't throw out a 88mm block either. Not ideal but for approx 300rwkw should be fine IMHO
Every one has a different idea on what's "safe" I personally would not use a 88mm bore in anything other then an N1 or RRR block
Given you can get a whole running original bore RB30 for between $0-500 I personally wouldn't risk it, but that's just me :yes:
  • 3 weeks later...
There is a lot of forged piston designs and shapes , is there a shape of piston that is best suited to an RB engine, eg flat top compared to the stock design, and also with a neo or non-neo head?
Would a flat top piston be less likely to get detonation due to being more uniform with no valve cut outs and more efficient due to being flat?
Some pistons have the top ring landing closer to the top, is this preferred, and what about the silicon contents of the latest pistons on the market.
Apparently some BMW's have forged pistons and they are designed to be quiet and smooth due to the increased silicon content which is quoted to be 14 percent compared to old days of 7percent, and compared to stock pistons having 12.5 %.
Just like with turbo's, HTA's are getting a name for the design and effectiveness, what about pistons and the head design of the RB, which piston is the HTA version for the RB.
Edited by AngryRB
im currently in the process of building a RB30DET (Forged 3.0l Bottom end, RB26 Head, GTX45, E85, Built C4). My engine builder has told me we want a 11.5:1 compression ratio because we are using E85. ill be looking to run 30+psi with this. Ive contacted Brad @ Spool Imports to see what pistons he can get his hands on that would get close to this CR. He reckons that they (CP Pistons) wont be able to fit enough Dome on the piston to achieve that. Another issue im looking at is, ill be running fairly high lift cams (between 9-11mm lift) so with such High compression im assuming ill have to fly cut the pistons which would lower the compression again surely. So what CR have people running high boost and E85 run and how did you achieve that CR (original CR of piston, work to block, HG thickness etc)?
also any hints on how to get as close as possible to my 11.5:1 CR?
Isn't the point of having an engine built by an engine builder the fact that they figure all that stuff out?
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
