Guys, VG30DETT rods are 2mm longer than the RB30 rods. And the RB25DET pistons have the shorter compression height, if I use both of these should give the correct height depending on combustion chamber volumes.
Does this sound like a viable option?
Probably firstly depends on the crank journal sizes - how much difference is there between the VG and RB rods? You'd need things side by side to measure up, and maybe look at a dummy assembly if you can get the bits at low cost.
Alternatively, why not look at just using RB25 pistons and deck the block by the required amount? Sure you might be retaining cast pistons and stock RB30 rods, but gets the result you want.
There should be a number of viable ways to achieve a similar outcome. It takes $$ to put in the parts that make for a stout 30DET, but the lower spec pistons and rods would still make for a good street build IMO.
Given the options, I'd rather install a longer rod (from an engine that was factory turbo) opposed to decking the block to compensate for the lower height pistons. Also, I'm aiming to get a comp ratio approx 9:1 so I think there would be a fair bit of block decking to reach that with just the 25DET pistons, apparently the galleries start widening once you take off 2mm off the block.
From what I've read the VG30 rods fit in the RB30 block/crank, might need to organise something different for the gudeon pins/bearings depending on the piston used.
But this all depends on combustion chamber volume, if the block and/or head need shaving to ensure it's true, from the rough calcs I did, the VG30 rods and RB25 pistons could result in compression ratios over 10:1, in which case I may need to use RB26 pistons (lower compression height again). Also, another thing I need to factor is if the block is worn and needs boring out I'll need overbore pistons, which may prove difficult to find 2nd hand.
Basically, I see it the similar as using factory RB30 rods and pistons, instead the rod happens to be longer and the piston a bit shorter. The parts are going to be balanced and new bearings etc installed either way and the VG30/RB25 parts can be obtained relatively easily and cheap.
Just want to know if it's stupid idea in theory.
Edited by daisu
7. SPOOL RB30 conrods and CP Forged Pistons $2050
Direct from their page
As opposed to picking up a set of VG30 rods/pistons for about $100 and haven't looked at RB25 piston prices but I'm assuming they would be similar priced.
Considering alot of people are making good power figures using standard bottom ends in both RB30's, VG30's, and RB25's I don't see the need to upgrade to aftermarket pistons/rods.
I can tell you for a fact that vg30 rods fit. thats what im using. However i got custom JE pistons made to suit and eagle rods. VG30 rods are 154mm (6.070in) and rb30 are 6in or 152.5mm thereabouts. so vg30 are 2.5mm longer, i havnt bothered trying to find out if they work with std. pistons etc. VG30 DOHC rods from 300zx etc have a 22mm rod bush, SOHC use a 21mm rod bush, same as all RB engines, so to start with youd need SOHC 300zx rods from something like a maxima. both VG rods use the same bottom end as RB so use the same bearings, even the acl website use the same partnumber
vg30 rods are about 1.5mm to 2mm thinner across the rod ( thickness ) than RB30 rods - so when using VG30 rods you end up with a rod that slides back and fourth on the big end journal.
Ah yes, I saw those pistons you had for sale on trademe.nz, question for you, with the pistons you had and using the VG30 rods you said it would give approx 8.3:1 compression ratio. Can I ask what was the compression height of the piston and whether how many CC's if it was dome top or dished?
If the VG30E(T) rods have the correct bush size then this would be easier than machining pistons to suit 22mm pin or having bushes made to suit 21mm pin. Only problem is knowing how strong/reliable they are. The factory power output of the engine is very similar to the ratings of the RB30. We'll see if I can find some people pushing decent power through these engines on standard bottom ends.
K577M87 - NISSAN RB30 GTR DISH 6577M87 - $852.12 That's US dollars without shipping.
And I'm not making anywhere near 530kW. I really don't see the need to use aftermarket pistons in my application.
The rods being thinner could be a problem though.
K577M87 Wiseco Pistons Rb30 GTR, Used by UK owners and proven to work
$648.84 USD from No limit motorsport be around $120 usd ship
$770 USD delivered + Spool rods $750 AUD= saves u around $500?
since they sell CP pistons + rods for 2k
'Spoolup', do you know how this issue is overcome on the VG30 engines by any chance?
yes that is exactly corret - on the VG30 there are two rods per journal ( being a V6 ).
So the width of the journal is just different to the RB30 and that is why the VG30 is different
i dont no for sure but i would presume that the crank is just sized/designed differently to accomodate the thinner rod.
for your power - just run a set of std RB30 rods and NA RB30 pistons - they will handle it and obviously a direct fit with no issues.
$1500 is still much more than I want to pay when standard items have been proven more than capable in the power range I'm aiming for.
Edited by Spoolup
this may be a stupid question for sum, but do you get your block work done and then purchase your pistons and bearings so forth or do you just get over sized pistons and then got the block done to match. or does it not really matter what way you do it
Yeah, I was contemplating just using standard rod/pistons, but as said before I want higher comp.
I guess I should start by CC'ing the head and having the block checked first. No point in figuring out I can use X pistons only to find out the block needs to be bored out and the pistons won't fit anymore.
I'll just have to go with decked block/shaved head and thin head gasket.
I would assume you'd have the block inspected first and then decide if oversize pistons are needed. Or if you had already planned on oversize pistons I guess it wouldn't matter which way you did it.
Clarification please?
Edited by daisu
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
