hey ;)
Make: Nissan
Model: Stagea S2
Milage: 115,XXX
Transmission: Tiptronic Auto with steering wheel shift
Colour: Electric Yellow
Complied? Yes
RWC supplied? Yes
Currently registered? Yes, fresh 12 months rego (NSW) included
Price: $25,000 neg $23,800
Contact: Bryce, 0412 836 036
Comments / Modifications:
STANDARD FEATURES:
RB25DET NEO
Tiptronic Automatic with Steering wheel shift
ATTESSA AWD System
Xanavi TV/Navi/Touch Climate Control/Touch Audio Control
Nissan Security
Various Dayz Options
Power Steering
Climate Control A/C
Dual Airbags
More Features
FRONT DOOR POCKET
CONSOLE POCKET (AT ONLY)
INSTO POCKET
FOOTREST
FUEL FILLER LID OPENER
FUEL GAUGE • DOOR OPEN WARNING
KEY WARNING • HEADLAMP WARNING
INGNITION KEY LIGHT
REMOTE CONTROL ENTRY (BACK DOOR INCLUDED)
DRIVER & PASSENGER VANITY MIRROR
ANTI BACTERIAL STEERING WHEEL & GEAR KNOB(!)
OZONE SAFE CLIMATE CONTROL WITH CLEAN FILTER
POWER STEERING
POWER WINDOWS
CUP HOLDERS
DRIVER LUMBAR SUPPORT
DRIVER DUAL SEAT LIFTER
FRONT SEAT BACK POCKET
REAR CENTRE ARMREST
REAR SPLIT SEAT (6:4)
TUFTED LUGGAGE CARPET
LUGGAGE SIDE POCKETS
LUGGAGE UNDER POCKET
LUGGAGE FLOOR HOOK
LUGGAGE SIDE HOOK
LUGGAGE HANGER RAIL
BACK DOOR GRIP
TONNEAU COVER
REAR SEAT RECLINER
REMOTE REAR SEAT DROPPER
REVERSIBLE LUGGAGE FLOOR
LUGGAGE ROOM 12V SOCKET
ENGINE:
HKS High Power Silent Serise Cat-Back Exhaust
AM Performance Split Front-Dump Pipe
Coolingpro Type-2 FMIC
Splitfire Coilpacks
Apexi Power Intake
Silicone Inlet Pipe
Earthing Kit
Turbo Timer
- Standard Boost – Never Adjusted
- Mechanically Excellent. Always serviced with premium products on time
SUSPENSION:
Standard
- Great Condition, very firm but could use lowering to complete the look
BRAKES:
Standard
- all pads at about 60-70%
WHEELS:
ROH Modena 3 piece 18x8 Front - 18x9 Rear, Custom Made.
Black Ultra Light Weight – Open Ended Wheel Nuts.
EXTERIOR:
R34 GTR Front End Conversion
- Genuine R34 GTR Plastic Bumper
- Genuine R34 GTR Aluminium Bonnet
- CCubed Side Guards
- CCubed R34 GTR Lip
- CCubed headlight mounts
- NISMO Clear Indicators (front and side)
- Carbon Fiber Air Guide
- Carbon Fiber Bonnet Hinge Adapters
- Light Weight Fiberglass Reo
- genuine bonnet seal
Customized Takeros Side Skirts
Takeros Rear Bar
De-Badged
- Exterior Recently Restored, everything in perfect condition
Dark tint all round
Tail light covers
rear guard flairs
INTERIOR:
Standard
Great Condition
EXTRA COMMENTS
This car has been a passion project with the highest standard for upkeep and modifications. Enthusiast, non smoking owner :D
12 months nsw rego included
SPECIAL THANKS
www.ccubed.com.au
www.skylinesaustralia.com
Images:
thanks for looking :laugh:
Edited by Brycey
https://www.sau.com.au/forums/topic/212690-fs-1999-s2-stagea-rs-four-dayz/
sorry about that mate, all the info is back up, for some reason half of the info got cut out.. all fixed now
:laugh:
Edited by Brycey
cheers mate ;)
yes it can :) its not a direct crossover (in the sense that you switch the engines, turn the key and its good to go) stuff like the electrics etc would need to be changed over but it has been done and is relatively common. the engine itself is a direct fit and bolt up. if you wanted more info ask the guys in the stagea section because i don't know how involved the conversion would be.. pretty sure a 5 speed box would need to be dropped in aswell
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
