Fs: 1999 S2 Stagea Rs-four Dayz
hey ;)
Make: Nissan
Model: Stagea S2
Milage: 115,XXX
Transmission: Tiptronic Auto with steering wheel shift
Colour: Electric Yellow
Complied? Yes
RWC supplied? Yes
Currently registered? Yes, fresh 12 months rego (NSW) included
Price: $25,000 neg $23,800
Contact: Bryce, 0412 836 036
Comments / Modifications:
STANDARD FEATURES:
RB25DET NEO
Tiptronic Automatic with Steering wheel shift
ATTESSA AWD System
Xanavi TV/Navi/Touch Climate Control/Touch Audio Control
Nissan Security
Various Dayz Options
Power Steering
Climate Control A/C
Dual Airbags
More Features
FRONT DOOR POCKET
CONSOLE POCKET (AT ONLY)
INSTO POCKET
FOOTREST
FUEL FILLER LID OPENER
FUEL GAUGE • DOOR OPEN WARNING
KEY WARNING • HEADLAMP WARNING
INGNITION KEY LIGHT
REMOTE CONTROL ENTRY (BACK DOOR INCLUDED)
DRIVER & PASSENGER VANITY MIRROR
ANTI BACTERIAL STEERING WHEEL & GEAR KNOB(!)
OZONE SAFE CLIMATE CONTROL WITH CLEAN FILTER
POWER STEERING
POWER WINDOWS
CUP HOLDERS
DRIVER LUMBAR SUPPORT
DRIVER DUAL SEAT LIFTER
FRONT SEAT BACK POCKET
REAR CENTRE ARMREST
REAR SPLIT SEAT (6:4)
TUFTED LUGGAGE CARPET
LUGGAGE SIDE POCKETS
LUGGAGE UNDER POCKET
LUGGAGE FLOOR HOOK
LUGGAGE SIDE HOOK
LUGGAGE HANGER RAIL
BACK DOOR GRIP
TONNEAU COVER
REAR SEAT RECLINER
REMOTE REAR SEAT DROPPER
REVERSIBLE LUGGAGE FLOOR
LUGGAGE ROOM 12V SOCKET
ENGINE:
HKS High Power Silent Serise Cat-Back Exhaust
AM Performance Split Front-Dump Pipe
Coolingpro Type-2 FMIC
Splitfire Coilpacks
Apexi Power Intake
Silicone Inlet Pipe
Earthing Kit
Turbo Timer
- Standard Boost – Never Adjusted
- Mechanically Excellent. Always serviced with premium products on time
SUSPENSION:
Standard
- Great Condition, very firm but could use lowering to complete the look
BRAKES:
Standard
- all pads at about 60-70%
WHEELS:
ROH Modena 3 piece 18x8 Front - 18x9 Rear, Custom Made.
Black Ultra Light Weight – Open Ended Wheel Nuts.
EXTERIOR:
R34 GTR Front End Conversion
- Genuine R34 GTR Plastic Bumper
- Genuine R34 GTR Aluminium Bonnet
- CCubed Side Guards
- CCubed R34 GTR Lip
- CCubed headlight mounts
- NISMO Clear Indicators (front and side)
- Carbon Fiber Air Guide
- Carbon Fiber Bonnet Hinge Adapters
- Light Weight Fiberglass Reo
- genuine bonnet seal
Customized Takeros Side Skirts
Takeros Rear Bar
De-Badged
- Exterior Recently Restored, everything in perfect condition
Dark tint all round
Tail light covers
rear guard flairs
INTERIOR:
Standard
Great Condition
EXTRA COMMENTS
This car has been a passion project with the highest standard for upkeep and modifications. Enthusiast, non smoking owner :D
12 months nsw rego included
SPECIAL THANKS
www.ccubed.com.au
www.skylinesaustralia.com
Images:
thanks for looking :laugh:
Edited by Brycey
cheers mate ;)
yes it can :) its not a direct crossover (in the sense that you switch the engines, turn the key and its good to go) stuff like the electrics etc would need to be changed over but it has been done and is relatively common. the engine itself is a direct fit and bolt up. if you wanted more info ask the guys in the stagea section because i don't know how involved the conversion would be.. pretty sure a 5 speed box would need to be dropped in aswell
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
