Okay guys, heres the deal, yesterday was tuning day for me and my freshly built rb25/26 hybrid. Well we had serious problems getting down there non car related it was a long day...
I'll cut to the chase, car started out AMAZING, 500 rpm increment pulls with the microtech lt12s slowly but surely adding fuel with 14psi through the gt35r. We were making 300ftlbs at 3000 rpm.... We made 387rwhp and 345 ft lbs at 5500 rpm loads at 14 psi. Never got to make a full sweep yet... At that point we were running out of fuel. The nismo FPR cant handle the dual pumps or something, and is not raising its pressure properly. So I ran down to Jegs and got an aeromotive. Hooked it in cant get the base FP down any lower than 55-56 with vac, it just wont go any lower... So tuning was compensated for that.
Now heres were it gets weird. Our numbers started falling off, yet the motor sounds extremely strong, no different then it was before. So after a few ramps at 4000 we are only at 200 is ft lbs now about a 1/3rd or a bit less than before... we decided to check the plugs. They were fine, A/F's are 11.1-11.3 the entire time, with little timing seeing around 16-17 degrees the coming back down as boost was added which was now around 16-18 psi (we didn't touch the MBC). Super super conservative tune, but no power now? So we do a compression check and leak down test cylinders are all 150+ish, leak down test is 95-100% across the board.....
We are coming to the conclusion the valves are leaking under pressure. Or they just arnt opening enough. Some of my lifers were squishy.. right after we shut it off and some are rock hard how they should be and others were soft. Theres no lifter tap however. You guys think the lifters are preventing my valves from getting proper lift thus the drop in HP? Or it could be the springs being weak and leaking off? I'm only at 8.5mm lift and 264in-268ex duration...
Anyone ever seen a similar problem such as this? They car is drivable, it sounds like a ****ing animal, holy **** the added displacement and modifications makes it sound so scary.... I've got footage and **** I need a buddy to send it to me so I can show some of the pulls. But right now shes a total dog. It idles great, No boost leaks nothing of that, we checked everything....
Also the injectors are re flowed to 740cc's they are from a reputable company who has been proven and known for their injectors.
lets hear some other opinions on the matter... I'd really like to know what the deal is. I'm leaning towards a valve related issue.
https://www.sau.com.au/forums/topic/212699-rb27-tunning-problems-and-issues/
what pressure were you running with the nismo fpr? how was the tune "compensated"? wouldn't you need a retune for a different base pressure.
how were the injectors re-flowed? i know you said they were done by a reputable company and thats great if you trust them, but i was of the assumption that they flow what they flow from the factory. correct me if i'm wrong.
nah you can get injectors highflowed. but some companys dont like this idea, they say it doesnt give as good of a spray pattern as a injector already built for XXX about of CC.
personally i havnt had personal dealings with highflow injectors...so i cant comment if they are good or bad.
My 20 cents;
Compression and leak down tests would show up leaking valves due to insufficient valve spring seat pressure. Although it won't show up oil pressure leak down of the followers. But leaking followers usually means rattling on start up, which you report isn't there. So I doubt it's a valve issue.
Did you check (with a timing light) that the ignition timing actually agrees with what you have mapped?
Have you tried dropping the exhaust? We had a flexible joint fail on a car on the dyno recently and it blocked the exhaust flow. All the numbers (A/F ratio, knock etc) looked OK, but it just dropped power by 25%. I tried the usual drop the exhaust at the first joint and it picked up the lost power straight away, some examination with a torch showed up the restricted exhaust flow.
You may also want to check the inlet pipework for a similar collapsing problem, although that generally shows up in a loss of boost.
Cheers
Gary
My 20 cents;
Cheers
Gary
Gary,
I see what your saying with the valves being shown leaking in a leakdown/compression check. However wouldnt they just get pushed up and closed from the cylinder pressure and not leak? I'm thinking when the boost is coming on. On the intake side port when the valves should be closed the boost pressure in the plenum runners is forcing them to open due to weak springs?
I have a reason the springs could be possible weak. When I rebuilt a few of the hydro lifters that were squishy before reinstalling them. However I re-installed the bleeder valve upside down, causing the lifter to be to tall and incompressible. This made the valves leak. So I had to remove them all and install lifters I had laying around from another motor. But the motor was cranked with these lifters installed wrong a hundred or so times... now I'm not sure what type of lift I would have been putting on these springs but I feel like I might have fatigued them. It seems so strange that the power we were making went away after our best pull when the numbers were starting to get up there. Possibly just finishing my springs off?
After we ran into this hp issue the boost was actually higher than it was before even though the MBC wasn't touched. (from 14 psi to 17-18psi)
Also 3000rpm had the same hp/tq basically as 4500rpm.... There were no gains like there was before (172hp/300ftlbs@3000 to 282hp/330ftlbs@4500)
I can check my exhaust, its just pretty much a straight pipe. 2 mufflers and one connection. Its possible the gasket for that broke and is hanging in the pipe? I'm doubting it but I know you are saying. I've seen a bad cat absolutely turn a truck into a dog due to being clogged just killing the power.
thanks, any more ideas insight would be greatly appreciated.
-Cory
****UPDATE!!****
I found a big boost leak after I was working on my car... fixed it took the car out for a drive and it felt a LOT better however...
Well it appears as if my ***-Dyno is off by over 50%. We got back on the dyno today, only to see my issue did not go away. The boost leak fixed spool times and response, but didn't fix ANY numbers...
We are making 200ft-lbs at 2000 and at 4000 with 14 psi. Fuel pressure is all straightened out now. Holding 45psi vac off at idle. Didn't change at all day. The car just has no balls. Dont get me wrong, its not slow, but its no where near what it should be.
Everything is basically perfect. Air intake temps, water temps, a/f ratio (11.1-11.3 at WOT), timing is spot on as well, plugs are great, good equal burn pattern and no missing..., muffler is not clogged by any means.
I drove down with my buddy who owns and EVO 8, my car is basically as fast as his bolt on EVO.... to give you an idea, but its not making numbers of what it should be.
We really are thinking that its something with the valves/lifters/springs.
Springs possibly weak and when boosting begins they start leaking at the intake ports that are supposed to be closed. (so the back of the closed valve stem is being pressed down by the 14-15 psi in the plenum)... even if it is just a little bit, its enough...
Or I have some bad lifters, but I'm doubting that since we have no lifter tick. Even this morning I turned my car on it was 32 degrees outside and no tick....
opinions would be greatly appreciated. As nice as it is to drive my car now, I feel like I have wasted xx,xxx dollars just to make it as fast as it was before...
The head I'm using is not my old head but rather someone elses...so I'll I know about it is that the valves hold cylinder pressure... but I don't know about boost...
I'd really appreciate ideas, I'm getting very stumped...
-Cory
The Tomei type A springs will be good.Up to 9.0mm lift and will rev to 8500rpm.
Im not saying this will fix your problem,couldnt hurt though considering you will eventually be putting big power through it.
Yeah it is a good idea, how do you know which washers to pick?
http://www.tomei-p.co.jp/_2003web-catalogue/efr_index.html
they are not bolts, they are allen keys that are weak as piss, you cant do them up without stripping them.
I have the exact same cam gear and i replaced 4 of them with 10mm bolts, which so fit in the grooves.
I am going to pull my cover off and check mine to make sure they have not moved.
its a cheap cam gear so this is what you get i spose.
But doesnt it feel good to know that you have found the problem!?
FYI: My Tomei valve springs arrived and they did not have the washers with them.
It feels amazing.
thanks for the tip Guilt Toy, I'll go look for some new hardware to tighten this gear better.
I cant wait to get back on the dyno to lay down so good numbers hopefully.
This car makes me wise and wiser with every issue. :blink:
Hence people should just mod the factory cam gear and make that adjustable
Never fails, cheap as chips :/
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
