i am a new skyline owner,i have a 1994 r33 gts-t with exhaust and air filter as only mods,i have filled my car up completely and have got 320kms and it says i still have 1/4 tank left.is there a fuel warning light on r33s just to let me know when im running low? my previous audi didnt have one and i ran out once:(
https://www.sau.com.au/forums/topic/212723-is-there-a-low-fuel-light-on-r33s/
Its a fairly faint brown light, hard to see in bright sunlight. Top Left of dash.
I didnt know i had one either, until one day i thought i was going run out of fuel, and then the fuel light came on for the first time - since then, ive worked out i have at least 30-40kms after the light comes on.
^^ Same here - one night i just kept driving around with the needle pointed on E (and the needle actually moves just under the E notch). I was pretty worried that i would run out sooner or later, and just as i rocked up to the traffic lights before the next servo i planned to stop at, the little orange icon lit up in the top left of the dash. I was cheering, I didnt think it had a fuel light at all.
Fuel light will come on when you're on E or just below. When it first comes on you still have a good 10L left (at-least), though you may find around corners your fuel fails to feed and you might chug a little! Haha.
But yeah, the fuel gauge is very lenient, it gives you heaps of warning. :D
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
