Hi guys,
I FINALLY received my HKS GT2835 Pro S kit from Nengun after waiting almost 2 months.
I thought I might take some pics to show everyone what's included in the kit:
1) Turbo itself (HKS GT2835 Pro S)
2) HKS Dump Pipe
3) Intake suction pipe
4) Elbow to connect to standard intercooler piping
5) HKS heat shield
6) Oil and water lines
7) Silicon hoses, clamps, nuts and bolts and other small parts.
Now, I've taken a pic of the 'serial' number on the turbo but I can't seem to identify anything.
How do I know that I've received the 0.68 A/R housing and not the 0.87? Can the gurus out there tell me how to identify this turbo appropriately?
Cheers.
By the cartridge number (700177-5003) its the right one for a "GT2835" Pro S .
If you look inside the turbine housings inlet flange (mounting flange) it may have a number cast into it just inside . If it does it'll say something like 0.68 or 0.87 which is the A/R size .
Cheers A .
Cheers A .
Yes you're right, I just had a look and it had cast into it '68'. I'm assuming they mean 0.68... haha
Thanks very much for your help discopotato!
post-48356-1206925523_thumb.jpgOne more question guys,
after close inspection of the turbine wheel, it looks as though it had been chipped or grinded.
As you can see in the pics, it seems as though when they manufactured it, they did it purposfully.
Do you think it has something to do with balancing, like they purposely did it to balance it?
I know when something spins as fast as a turbo does, the slightest amount of weight difference on the opposite side will through it out of balance and it will wobble. (Same principal as a wheen on a car)
Has anyone else come accross this issue with their turbo???
Thanks
They think they do this to balance the tubo. Ive seen alot more of the centre nut removed than what you have there.
I wouldn't worry too much about it.
Good luck with the install etc.
Edited by RedDrifter
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
