went to change the oil on the weekend only to find that the sump plug is well farked.
it is all rounded around the edges and it would not grab strong enough to turn it.
it's a 14mm head as the 15 is too big and 13 is too small, but the 14 just slips through when you apply a bit of force.
I even tried to use a shifter to get a really tight fit on to it but it's almost like someone put it on there with a ratchet gun or something.
so what are my options?
I assume some workshop will have some way of getting it off, once that is done, can I get a replacement bolt from any autobarn type shop?
repco or something?
or does nissan stock RB25 sump plugs?
and washers I suppose.
https://www.sau.com.au/forums/topic/212729-sump-plug-fudged/
repco or something?
Grab a file and file 2 sides a little smaller so you can fit a 13 mm open end spanner, that should do the trick. Another way to undo it get a pipe wrench on to itthat should work too. Whatever you do dont be tampted to drill it out. You should be able to gat another from Nissan or a spare parts shop.
Use an easyout. Its a screw bit with a reverse thread on it that you screw through the back of the plug. As it tightens it loosens up the other bolt
Weld another nut on the end
Try loosening with a 'true' hex fitting
Get an rb30 one from the wreckers i guess
Edited by Jmaac
wrx hoon is on the money, use a file and file it flat... but befor i tried that i would use a pipe wrench (stillsons)... just a small pair like a 8" pair will set you back around $20 MAX and they are handy as for stripped nuts, basically the harder you pull the more the teeth bite the nut
I would personally file them down. I've noticed that vice grips usually never works. Always slips no matter how hard you do it up. If the nut was tight enough to strip, the vice grip won't do much except round it even smoother (from my experience).
yea u could drill it..... or just use some vice grips. they work great on rounded bolts.
There are two types of these...Shit and Excellent....
If you use a good brand (not a $10 pair) you will have no troubles....They are made for this sort of problem...
couple of good smacks with a hammer and GOOD chiesel will make it move then replace with a new sump plug .
ive had to resort to this method a couple of times at work when cars come in for a service and the plugs are so tight or have been butchered by wrong size spanners been used . never had a sump plug yet that i could not get off one way or another
Laser!!?? do go on!!!
Love vice grips, but a stillson has been reported to once have ripped the soul from James Brown.
Spark plug wtf?
:laugh: Believe it or not, it was put in there by a workshop down here in Melbourne. A member had taken his car in for a service or something and he got the car back with a spark plug as the plug. hahhaha. I surprised to see that the spark plug will fit!
That spark plug is sad. If I ever did that, my boss would KILL me!!
This is one technique I want to try out, but have been too scared to yet. It would work for a lot of the cars that come into work.
1. Open fuel tank
2. Place rags into tank
3. Pour more fuel on to rags
4. Throw a match on to rags
5. RUN!!!!!!!!!!!!!!!!!!!!!
Should work for a whole lot of things, but like I said, I'm too scared to use it in case it bites me on the arse :laugh:
Edited by NA_Goodness
I have burrowed a some Vice grips from my neighbour.
Will try those first on Saturday morn when I get back under it.
I also burrowed a cold chisel if it comes to that.. :D
Will also buy some plugs on the way home tonight to make a morning out of it tomorrow.
BCPR6ES is it?
i've used a cold chisel in the past worked well and multi grips or vice grips, worked to, instead of replacing your sump plug get a big nut (meaning long length nut) and weld it on the end, done it with my commodore, worked a treat.
that way there is plenty of room to use a ring spanner and not have to worry about ever stripping the bolt again
    • Lol a few are like that with no intention of being reborn unfortunately.
    • Done, I'll do mine soon too - whenver I take out the car next. I can cheat and make it quieter by turning off VCT at idle too - but I lose the braps
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
