Hey all , im looking at getting the above mentioned car
just wanting to know how many km i should be looking at per tank and also , how much does it cost to fill a tank?
another quick q - how reliable are these cars , i know power is easy to get from them but am i going to be replacing the motor once it hits 150xxx km?
most seem to be around the 10x xxx km mark , so how many more kms do they have in them?
cheers guys and gals!
ps if anyone wants to show me there r33 gtst s2 manual that they have for sale in melb or close to , give me a pm and we can have a chat
https://www.sau.com.au/forums/topic/212741-r33-gts-t-s2-manual-qs/
should get 400+k's easy on a stocker depending on how you drive it. more for highway driving.
in general the car is very reliable, obviously the more you modify it the more risk of problems as with any car. that said there are always lemons in any bunch of cars usually because of how poorly the previous owner(s) have maintained it so always do a thorough check.
they hav plenty more k's on them based on how heavily modded it is.
all comes down to how its been maintained before it hits your hands.
yeah true. , everything seems to be around the 100 xxx km mark which is really just under 10k KM a year , so i suppose thats pretty decent.
i suppose im better off buying a stocker , but if i find something with a few mods ie exhaust,cooler,wheels it should be alright.
than for ya help
Mines a 32 not a 33 but I get between 450-500kms out of a tank every week but I probably dont drive as hard as most.Only mods to mine are Exhaust and pod filter(135kws at wheels) My 32 has just clocked up 235000 ks(Had it from 71000ks)and has been extremely reliable/nil breakdowns. It all how you drive/maintain them.cheers Marty
Edited by martyg58
Couldnt agree more with the responses here.
If its been well maintained you shouldnt have a problem at all. That said, perhaps at 150,000kms a few gaskets will most likley need changing if it hasnt already done so.
In terms of kms per tank. Anywhere from 350-450 depending on mods on the car and how you drive it.
If its seing something less than 300 than theres a problem with the car or how the car has been tuned (if it has)
Agree with everything that has been said here. But I'll just point out that most of them have had their clocks wound back at some point in their life. If its got 100xxx on the clock you may aswell add another 50 - 70 thousand kms onto that and you would be closer the mark. Make sure you look at the interior when your looking at one. Worn steering wheel, seats and gear stick cover are all signs that the car most likely has over 150,000kms on it. Also the syncros on 4th and 5th gear tend to let go in the r33's when you get into the higher kms. Give it a hard change into 4th and 5th if it crunches thats another indicator of the true mileage on the car.
Dont be put off by this though because they are still really reliable, as long as you look after them :) Good luck on buying one you won't regret it
Forget abotu looking at the KM's as stated above they are almost all wound back. For a real idea of KM look at things like the drivers seat, you will see wear on the outside hip support, also check the 'leather' on the handbrake boot, the wear on the gearstick and also on the steering wheel. This will tell you how much use the car has had
As for fuel consumption, if you really have to ask then it will cost too much. I have a big thread on fuel economy for R33 gts-t's, which will give you detailed info if you can be bothered finding it. Basically its all down to how you drive and if its city or freeway. When my cra was making 200rwkw i was struggling to get over 270km per tank, changed filters, plugs O2 sensor blah blah blah and it went up to about 320. My cra now has 250rwkw and i did a whole tank driving for economy (car only went above 12% inhector duty cycle 2-3 times) and hey presto i got 420km!!!
So as i said its all down to how you drive and the tune, thats if the filters and sensors are operating correctly.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
