4wd And Abs Lights Always Coming On
Hi stupid question rb25s2. Don’t have igniter is that igniter built in coilpacks or in the ecu
If you really want good AC consider the frenchies kit. All modern gear, works much better and is lighter. But it is $$$$$$
Un able to check it at idle as it won’t idle for me long enough to try, best I’m able to do is with ignition on engine off and no matter where I turn the tps the voltage doesn’t change from 5.10, if I unplug afm it will idle longer but won’t turn off with ignition, have since swapped afm to no real change
Sorry to sound thick....but what does the "faceplate" have to do with adjusting the odometer? Surely the odo stays put and you change the fascia. Surely they are not the same thing.
