As with f.pumps, inj's, ECU's etc, I would personally only use something proven. Theres a reason the known brands are 300%-600% more exspensive.
Just my boo boo view :)
yeah i get your point and agree but i think brands like turbosmart are way overpriced. i just dont see the value for money. looks like i will have to bight the bullet though and buy a turbosmart one,
thanks
Justin
I love a bargain priced car part as much as the next guy, but id rather pay once for something that lasts and doesnt break than pay for a failure and then the top end model part
Im not saying the JJR one is shit. But i am saying the turbosmart one is proven :)
thanks
Justin
Local merchants of poverty IMO
So much mark up, $1,100 for thier 50mm? Thats %10 less then the HKS GTII
TiAL is US$600'ish for thier 50mm.
Just saying humbug to Turbosmart,
EDITED:
...not saying the JJR one is shit. But i am saying the turbosmart one is proven :)
True, but TiAL is more proven'ed :P
Edited by GeeTR
i think i may just get GCG to bore out my internal wastegate hole....$395 to bore it out from 27mm too 37mm. problem im having is it just isnt flowing enough and im getting massive boost creep because of it. but my main prob with this is the turbo is a new gt3540r IW and why havent garrett done the maths to allow the internal gate to flow enough???? its not as though im only trying to run 10psi... im trying to run 18-19psi through it and still get boost creep at the top of the rev rang as high as 24psi. my tuner surgested going 50mm external but its just too much trouble, and im not sure there will be enough room on my exhaust manifold to weld a external wastegate pipe into the collector area.
thanks
Justin
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
