Dude.... I walked into a dyno shop which had 2x R33s out the front in so I assumed yeah they might know something.
I was like yeah I have an RB30DET, 40 thou oversize, big cams, forged internals, lots of head work, big injectors, big turbo blah blah blah...
Then he was like umm... why are you running a VL engine in your car..... I was like omfg I hate people who say that.. its an RB30 block with an RB25 head. he looked very confused and then said well $1500 for a tune. leave it with us for a few weeks and we will see what we can do.
A guy owns a performance shop here, I buy a lot of stuff off him and hes from QLD. He said that all of the tuners here he wouldn't even trust them to do a power run and that he is getting a tuner down from QLD to tune his car for him and hes going to hire a dyno for him to use. I am going to get him to tune his car for me when he comes down.
Well go to some one else who has half an idea. Unsure how it is in tas but in little old country town Adelaide we have over 5 good tuners. There's only one that I wouldn't trust with my car.
Im sure there is a decent tuner there in TAS surely there not all numb nuts.
Regardless there's nothing special about an rb30det. Its simply a stroked rb25 so a dyno would have shown there's a fuel issue; at that point the fuel return would have been dropped and straight away it would have been known there is a fuel supply issue. That is standard fuel supply troubleshooting regardless if he didn't know an rb30det existed or not.
If the dyno tuner can't do the above then he would not be operating.
I hope you have a little more luck running the 30det on the stock ecu than I did. Anything above 6psi at 3000rpm saw fuel cut.
:D
Ditto, CEF11E's remap sorted that till I could get in for a remap to suit z32 afm and bigger injectors.
  • 5 months later...
Guessin that he has found a DYNO Tuner he can trust and that is not an idiot as he has finally got it booked in for a tune next week...
Or maybe I should ring Brad up and tell him some of the shit you been sprouting on here about the idiots that cant run dynos in TAS.
Seriously, do you think that nobody reads this crap you post and that it wont come back to bite you in the ass someday??
I am almost embarressed to admit that I have just bought a Skyline now.
Might go join a VOLVO forum...
but then your probably a technical expert over there as well arent ya Finny??? :ninja:
How much power are you expecting from your 25/30??? Or how much did it make???
Brad at boost automotive tuned my old RB25 to 399rwkw at only 17psi, and I will be taking my engine setup there for a tune also. With a big shot of NOS to get things moving.
How does a 023 pump compare to a 044???
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
