Hi guys,
I'm thinking about putting a pod filter in the stock air box. what are u guys reckon? is this gonna be better than pod filter with custom air box? also, think about getting air induction from the front and feed into the stock air box for the pod.. good or bad?
Cheers
its been done before, sau member limpus has placed a pod inside the airbox, maybe if he see's this thread he will post some info :D
good luck fitting a pod in the factory box lol
In that case i must be really lucky because i have...
My apexi pod is hidden inside my stock arbox with a metal intake pipe coming from my 2535 and a Z32 afm...its all about backyard ingenuity...personally i did mine because i had a spare apexi pod in my garage and felt bored one day...and most cops are non the wiser...
So the bottom line is...YES...you can fit a pod into an airbox...but it will take some trimming of parts of the airbox to have it sit nicely...my airbox is butchered anyway with a larger section of the base and side removed...it just helps to get alittle more air in...when i'm at the track i just rip the whole cover off and expose the whole pod...
As for whether it improves or hampers performance...you make up your own mind...i have done a couple of back to back dyno runs with and without the cover a year ago and power was almost the same...however it should be noted that this situation is not the same in real world conditions when you're doing 120km/h and ramming air into the engine bay...
I don't have a pic of the box with the pod inside but here is the engine bay with the airbox...the aim is to have it looking legal...
I understand Limpus was bored and had a filter to play with and had a butchered box already so did this.
what about you subie?
why do you want to do it?
What is your reasoning behind it?
why/how do you think it's going to be better than even a stock NISSAN paper panel filter element in the stock air box using stock ducting?
Stock air box all the way
Z32 AFM also bolts straight up to it - half the time people don't even know what they are looking at so they won't realise its a Z32 AFM
Just use the stock air box with a paper filter man, you really can't go wrong
I have had to go back to an Apexi power intake filter as my standard air box doesn't fit with my new piping setup (intake and cooler) which really sucks to be honest
I'm just waiting for the day I get pulled over and raped! :(
One weekend when I am free I might attempt to make the air box fit, it is possible but just takes time to do it
Plenty of people making high power figures on standard air box - why wouldn't you use it?
Gday guys! :( I'm a new skyline owner and have to say these forums are awesome! I've been reading it for days on end and getting no sleep :D
Anyway, on to my newb question(s):
The skyline i bought (R33 GTST) came with a HKS mushroom filter, which i find to be bloody noisy and have ordered an Apexi power intake filter (or whatever they're called) to replace it. I was planning to put a box around this for legal issues, and was also considering setting up some kind of CAI piping into the box, but after reading it sounds like everyone touts the stock box/intake as superior for close-to-stock cars (mines got only the filter and a ?cat-back? exhaust AFAIK)
So i was wondering what would be the best option:
1. Find a stock box + intake, hack it to fit the Apexi (pod) filter.
2. Find a stock box + intake, forget the pod filter, use a k&n panel filter instead (totally stock setup)
3. Foget the stock box/intake and just build a partition/box for pod & a CAI
If the stock options are best, where to find them? Seems most cars have pod filters installed lol, so surely those original parts must be lying around somewhere?
Also, what's the Z32 AFM? I assume that AFM = Air Flow Meter, is Z32 the stock meter attached to the intake pipe after the filter?
Appreciate any advice :(
use the stock box, intake and filter.
sell the pod.
Z32 is the 300zx.
their AFM meter has a higher max voltage which means more tuning resolution.
I got the same as you (sort of)
just bought an R33, has a cat back and blitz pod.
I will be replacing that with the stock intake stuff soon.
I only get to play with the car a little bit on weekends so gotta get the service and stuff out of the way first.
I agree..
the sound is f*king annoying.
sell the pod.
Z32 is the 300zx.
I agree..
Thanks for the input GTST! Where do you plan to get the stock parts from?
Putting Apexi Pod in a stock box = just to keep the heat away from the pod and hide it.
I gota friend who did that and it worked quite well.
If your not running a large abount of boost just change it to a high flow panel filter.
what about you subie? I'm just thinking about it first and might try to to do it when i have time
why do you want to do it? instead of making the box, i wanna use the stock air box and make the pod fit in it
What is your reasoning behind it? cop and make it look standard
why/how do you think it's going to be better than even a stock NISSAN paper panel filter element in the stock air box using stock ducting? I don't know, that's why I make this topic to see others think..
Cheers
That noise isnt the nicest but it is all intake noise from stock compressor, Since hiflowing my stock turbo but still running pod filter its much quiter and makes a nice high pitch whistle on boost, not that rushing air sound that stock turbo makes.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
