confak Posted July 25, 2003 Share Posted July 25, 2003 I have found this turbo the 17cm one fora good price. I was thinking to put it on my RB25det. Would anybody hapen to know it uses the same bolt pattern to the standard exhaust manifold? Also i think that this turbo will be pretty laggy so i was wondering if it was possible to use a smaller trust exhaust comp. Maybe from a TD05 or a TD06 to bring boost on earlier. ould anyone know if these housings are interchangable or not and the difficulty/cost involved in doing something like this. Thanks Con Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/ Share on other sites More sharing options...
meggala Posted July 25, 2003 Share Posted July 25, 2003 not worth it con unless your doign the 25/30 conversion it would be very laggy and the exhaust housing woudl probbably cost more than the turbo also you need a trust manifold Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/#findComment-449285 Share on other sites More sharing options...
confak Posted July 25, 2003 Author Share Posted July 25, 2003 Thanks steve, Would it be possible to greate an adaptor plate to suit the bolt pattern of the torbo and the pattern of the manifold? Steve the turbo is Brand new and is extremely cheap to pass up the offer. I ahve an RB30 bottom end and plan to do the conversion in the future. Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/#findComment-449342 Share on other sites More sharing options...
confak Posted July 25, 2003 Author Share Posted July 25, 2003 Also i have seen plenty of second hand TD05 turbos off lancers going around. They seem pretty cheap so would it be possible to use the ex.housing of those? Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/#findComment-449353 Share on other sites More sharing options...
meggala Posted July 25, 2003 Share Posted July 25, 2003 I'm not sure about these turbo but i know they have different flanges and are normally top mount not low mount like your stock turbo. also you will need an external waste gate it would be perfect for your rb2530 but a waste on a stock rb25 talk to your work shop they should know cheers Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/#findComment-449366 Share on other sites More sharing options...
confak Posted July 25, 2003 Author Share Posted July 25, 2003 Thanks for ypu help steve. If anyone else knows anything about this turbo could you give me some advice and thoughts. Cheers Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/#findComment-450429 Share on other sites More sharing options...
Guest INASNT Posted July 26, 2003 Share Posted July 26, 2003 If u r gonna spend money on such a nice turbo then u would want a custom made manifold to high mount it and ext gate. Thats when the $$ figures jump up. I am in the process of doing a 3037, custom manifold and ext ate at the moment and its costs alot of $$ to do it right Link to comment https://www.sau.com.au/forums/topic/21283-trust-td07-25g/#findComment-450493 Share on other sites More sharing options...
