1. r33 GTR rear brake calipers with pads in there with meat on there - $ 180
2. r33 gtst rear brake discs -$160 for both
3. brand new r33gtst bendix ultimate brake pads in the box for sale $75, code on box is DB1170 ULT, says they fit gtr"s when i searched on google but not to sure if some1 wants to add there view on this that would be fine
this is perfect for a brake upgrade for a silvia for the back end, or if any1 just wants to grab either of the 3 i dont mind
mitch
sutho shire nsw
0405 204 561 or pm me plz
cant be botherd posting intersate hoping for some1 in sydney just to pop around!!
https://www.sau.com.au/forums/topic/212836-brakes-for-sale/
  • 3 months later...
The rear calipers have the solid brake lines and the flexible rubber ones ?
If so I'll give you $150 posted. There are a couple of pairs cheaper on ebay atm, but with yours I'll know what I'm getting.
mitch
sutho shire nsw
https://www.sau.com.au/forums/topic/212836-brakes-for-sale/#findComment-4025750
gerry, as far as ur qestion the rubber brake line is flexy yes..and whats in the pic is what you get
and there are pads also in there ready to go
i was told u need the hand brake cable or somthing also?
yeah thats fine, plz pm me your delivery details etc if your keen and i will pm u my bank details
mitch
https://www.sau.com.au/forums/topic/212836-brakes-for-sale/#findComment-4025763
