Ok I've stripped my R32 Rb20 Front Halfcut.... any there are heaps of parts i don't need.
i'll list all the main parts, and as per forum rules... i will post a price, if you are unhappy with my prices, please keep in mind all these prices are negotiable!
~ Prefer Pickup, parts located North Eastern Suburbs of Melbourne
~ Contact Mark on 0408 569 685
______________________________
INTERIOR
Centre Dash piece (good condition, its the big dash bit that goes in the middle where the radio etc is) - $15
Accelerator pedal and bracket - $10
Brake Pedal, bracket and sensor switch - $15
Under dash front intrusion bar (very good condition) - $5
AirCon core box (very good condition) - $20
Under dash fan box (very good condition) - $15
Glove box (quite good condition, small plastic mount snapped, but easily repaired) - $15
SUSPENSION AND STEERING PARTS
Std Shocks and Springs ~ front pair only (very good condition, not leaking) - $35
Std Castor rods ~ pair (excellent condition, bushes look brand new) - $45
Std 5 stud Hubs and Rotors ~ front pair (hubs and disk rotors in great condition) - $70
Std Upper control arms ~ front pair (very good condition, perfect if yours are bent from accident) - $45
Std Sway bar (very good condition) - $25
ENGINE BAY PARTS
Carbon canister (very good condition) - $15 Sold pending payment
Clutch Fan (quite good condition) - $15
Solid Brake lines ~ front pair (very good condition) - $10
Windscreen Wiper Arms ~ complete (good condition, but need a coat of paint) - $10
Windscreen Wiper Motor - (very good condition) - $15
Bonnet release cable and latch - (very good condition) - $15
Bonnet hinges ~ pair (good condition) - $5
AirCon reciever dryer and condenser (very good condition) - $20
____________________________________________________________
if you need something that isnt listed here, ask me anyway as i may still have it
Edited by Ruffels
Hi mate,
is this the whole thing or just the centre console surround (the bit that go around radio and down to gear boot)
if this is the surround part, I'll take it, can u post it to 2250 NSW?
How much all up?
Cheers
Edited by subie
Hey mate, do you have a drivers aApillar interior trim? (with no holes(i know its a big ask))
If so could you please PM me with price and i will pick up.
Thanks!
Femno, unfortunatly they cut the car at the a pillar, so i don't have those trims, sorry!
Rad33, all main vents are either missing or damaged, however i have circular drivers side vent, and the small vents that blow at the windscreen and at the side windows
do you have all the demister airvents for the top dash?
are they warped/cracked from the sun?
Ill take them :P
edit; will also take the door hinges if the rubber is perfect on them.
Can you PM me some pics?
What suburb are the parts located?
ALL PM's Replied!
________________
sorry mate, forgot to mention that i'm keeping all engine and gearbox components for an engine swap into another car... just selling bits i don't need
once again i appologize about the confusion
-Mark
how much for afm? pm me
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
