Hi all, I'm thinking of buying a GT-R, preferably R33, but I'm having a hard time finding a good buyer's guide. Specifically I want to know:
1) What are the problem areas/ things to look out for or test when I'm looking at one
2) How to tell the difference between a REAL GT-R and one with a body kit!! I don't want to be ripped off into buying a fake! I know a little about engines and stuff, but am not at all familiar with a skyline's engine bay, anyone got some good detailed pictures of STOCK engines, since modified engines can look quite different?
3) How do I tell the difference between a V-Spec and non-Vspec, and one with a V-Spec body kit!! I dont mind either, but obviously dont want to pay V-spec price for a non-V-spec.
Any help / links appreciated
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/
Quote from Autospeed Article: Although we've said it's a supremely flexible engine, if you're pottering in a cruising gear, don't expect to be sucked back into a GT-R's seat - no matter how hard you put your foot down. The 2.6 litre six makes peak torque of 355Nm at 4400 rpm, so it still has to be driven like a true turbo car - if you wanna go hard, you need to row the gears. In contrast, what about the Toyota Supra's 3 litre 2JZ-GTE? With 431Nm delivered at only 3600 rpm that's an engine!
Bollocks. I can`t stand it when "experienced" journalists can't see the car for what it is: in this case, a shit hot race car. The engineers at Nissan designed the BNR32 to do one thing... win races.
So whats all this about you need to "row the gears"? Is using the gearbox not what DRIVING is all about? If I wanted to get in a GT-R and not have to change gears, I would`ve bought shares in Nissan and then developed an AT option.
Sounds like he drove a 5.7 V8 to the GT-R test location...
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-449379
Thanks for the replies guys.
I already saw the jbskyline article, I think I know a little about what R33's and V-specs are about, I just need more details about the "known problem areas" to look for when scouting one out, and how to tell if it's REALLY a GT-R, not just one with a GT-R body kit and stickers. I guess the twin turbos should be a tell-tale sign eh? And I suppose driveshafts to the front wheels means it's a 4WD...
Is there like a step-by-step article someone has put together on taking the engine apart or something? That would be informative.
What about how to tell the V-Spec from the non-V-Spec though? Anyone can put a V-spec sticker on it, but how do you tell which Atessa is the REAL thing?
Oh, and I agree the Autospeed article is complete bollocks. Talking about WRXs beating GT-Rs with an exhaust mod is ridiculous. He obviously does not know about the fake 280ps rule in Japan, and the fact that WRXes are front-biased AWD pieces of shit that understeer like a pig without a lot of work. Oh well, less people know about GT-Rs, more for me :P
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450146
I DO remember an old "High Performance Imports" article that dealt the differences between an R33 GT-R and a 33 V-Spec... aaah, I could be wrong, but I think theres a different main connector to the ECU in the V-Spec... and the rear diff housing has ribbing or something on the V-Spec... stuff that you can identify at a glance, like that. FOR GODS SAKE DON'T QUOTE ME!
Does anybody have that article? It must have been a '99/'00 issue.
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450193
A few things I'd look for (correct me if I'm wrong)
- ABS brakes: No ABS = no GT-R. Look for a bunch of brake lines going over to a control box somewhere in the engine bay :-)
- If the intake pipes stretch over the top of the engine, it's not a GT-R :D (a front facing plenum won't stretch over the top of the engine either)
- Look under the front wheels for a drive train / front diff :-) (GTS-4 is supposed to be 4wd as well)
- 2 turbos could be an indication also :-) (that should be a giveaway)
- The boost solenoid on a GTST is on the passenger side of the engine bay. I believe the boost controller on a GT-R is on the right-hand side(?)
- Look at the engine number... It'll probably start with RB26 instead of RB25. Down on the passenger side near the flywheel.
Doesn't the v-spec also have an active limmie? Perhaps you could look for control wires coming out of the rear diff...
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450242
someone could get a GTS4 and drop in an rb26 as well so just because its an RB26 doesn't mean its a real GTR.
the best thing i would say to look for is that the GTR has flared front and rear guards. These are expensive to change and would probably be a giveaway as to whether or not its a real GTR.
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450598
Great suggestions guys!
I guess the flared guards, RB26DETT, chassis no. and front driveshafts should tell me that it's probably a GT-R, although as Airzone and WarR32 said, nothing is a guarantee.
However, I still don't know how to tell a real V-Spec from a non-v-spec... Airzone you said a V-spec has an active LSD, but I thought so do normal GT-R's, its just that V-Specs have it tuned more aggressively (the LSDs I mean)? Anyone know if the ribbed rear diff housing is a key?
BTW, what is the "C" in the chassis number? Why are R32's BNR32, but R33's BCNR33? I believe R34's are BNR34 again (no C) What is the difference in the numbers between a non-GT-R chassis number and a GT-R chassis number?
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-451338
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
