Hi all, I'm thinking of buying a GT-R, preferably R33, but I'm having a hard time finding a good buyer's guide. Specifically I want to know:
1) What are the problem areas/ things to look out for or test when I'm looking at one
2) How to tell the difference between a REAL GT-R and one with a body kit!! I don't want to be ripped off into buying a fake! I know a little about engines and stuff, but am not at all familiar with a skyline's engine bay, anyone got some good detailed pictures of STOCK engines, since modified engines can look quite different?
3) How do I tell the difference between a V-Spec and non-Vspec, and one with a V-Spec body kit!! I dont mind either, but obviously dont want to pay V-spec price for a non-V-spec.
Any help / links appreciated
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/
Quote from Autospeed Article: Although we've said it's a supremely flexible engine, if you're pottering in a cruising gear, don't expect to be sucked back into a GT-R's seat - no matter how hard you put your foot down. The 2.6 litre six makes peak torque of 355Nm at 4400 rpm, so it still has to be driven like a true turbo car - if you wanna go hard, you need to row the gears. In contrast, what about the Toyota Supra's 3 litre 2JZ-GTE? With 431Nm delivered at only 3600 rpm that's an engine!
Bollocks. I can`t stand it when "experienced" journalists can't see the car for what it is: in this case, a shit hot race car. The engineers at Nissan designed the BNR32 to do one thing... win races.
So whats all this about you need to "row the gears"? Is using the gearbox not what DRIVING is all about? If I wanted to get in a GT-R and not have to change gears, I would`ve bought shares in Nissan and then developed an AT option.
Sounds like he drove a 5.7 V8 to the GT-R test location...
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-449379
Thanks for the replies guys.
I already saw the jbskyline article, I think I know a little about what R33's and V-specs are about, I just need more details about the "known problem areas" to look for when scouting one out, and how to tell if it's REALLY a GT-R, not just one with a GT-R body kit and stickers. I guess the twin turbos should be a tell-tale sign eh? And I suppose driveshafts to the front wheels means it's a 4WD...
Is there like a step-by-step article someone has put together on taking the engine apart or something? That would be informative.
What about how to tell the V-Spec from the non-V-Spec though? Anyone can put a V-spec sticker on it, but how do you tell which Atessa is the REAL thing?
Oh, and I agree the Autospeed article is complete bollocks. Talking about WRXs beating GT-Rs with an exhaust mod is ridiculous. He obviously does not know about the fake 280ps rule in Japan, and the fact that WRXes are front-biased AWD pieces of shit that understeer like a pig without a lot of work. Oh well, less people know about GT-Rs, more for me :P
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450146
I DO remember an old "High Performance Imports" article that dealt the differences between an R33 GT-R and a 33 V-Spec... aaah, I could be wrong, but I think theres a different main connector to the ECU in the V-Spec... and the rear diff housing has ribbing or something on the V-Spec... stuff that you can identify at a glance, like that. FOR GODS SAKE DON'T QUOTE ME!
Does anybody have that article? It must have been a '99/'00 issue.
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450193
A few things I'd look for (correct me if I'm wrong)
- ABS brakes: No ABS = no GT-R. Look for a bunch of brake lines going over to a control box somewhere in the engine bay :-)
- If the intake pipes stretch over the top of the engine, it's not a GT-R :D (a front facing plenum won't stretch over the top of the engine either)
- Look under the front wheels for a drive train / front diff :-) (GTS-4 is supposed to be 4wd as well)
- 2 turbos could be an indication also :-) (that should be a giveaway)
- The boost solenoid on a GTST is on the passenger side of the engine bay. I believe the boost controller on a GT-R is on the right-hand side(?)
- Look at the engine number... It'll probably start with RB26 instead of RB25. Down on the passenger side near the flywheel.
Doesn't the v-spec also have an active limmie? Perhaps you could look for control wires coming out of the rear diff...
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450242
someone could get a GTS4 and drop in an rb26 as well so just because its an RB26 doesn't mean its a real GTR.
the best thing i would say to look for is that the GTR has flared front and rear guards. These are expensive to change and would probably be a giveaway as to whether or not its a real GTR.
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-450598
Great suggestions guys!
I guess the flared guards, RB26DETT, chassis no. and front driveshafts should tell me that it's probably a GT-R, although as Airzone and WarR32 said, nothing is a guarantee.
However, I still don't know how to tell a real V-Spec from a non-v-spec... Airzone you said a V-spec has an active LSD, but I thought so do normal GT-R's, its just that V-Specs have it tuned more aggressively (the LSDs I mean)? Anyone know if the ribbed rear diff housing is a key?
BTW, what is the "C" in the chassis number? Why are R32's BNR32, but R33's BCNR33? I believe R34's are BNR34 again (no C) What is the difference in the numbers between a non-GT-R chassis number and a GT-R chassis number?
https://www.sau.com.au/forums/topic/21284-gt-r-buyers-guide/#findComment-451338
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
