Speed also did one when they did an R32 GT-R buyer's guide (6pages) in issue 3 last year... If you like i could mail you a copy (we've got s--t loads here). And Julian Edgar doesn't know s--t from clay. He reckons the GT-R is one of the worst handling cars he's driven as his R32 oversteered quite a bit. Couldn't have had anything to do with his excessive heavy foot could it? He also sang the praises of Mitsubishi Ralliart Magna and the sporty Verada Ltd edition. 'Nuff said. :)
Julian Edgar>:)
I remember when he just about made himself bankrupt by buying an R32 GT-R that he couldn't afford, then ****ed up the ATTESA by making some cheap "interceptor" cicuit, then proceeded to wrap it around a tree... :D
Originally posted by Sonic
He should do 2 things:
1) Stop writing as if other journos know nothing and are inferior to his opinionated prose that he spouts on AutoSpeed.
2) Stop touching kiddies.
:):D
AMEN...
my first check for an r33 gt-r are the rear flared guards. i dunno why anyone would bother having their gts / gts-t rear guards flared.
Even then there are a few out there that have the guards welded in.. and occasionally you'll see it in the Japanese auction lists. I mean its possible to do a full conversion, but it will cost you more than a GTR in the first place.
So in reality, if somebody wanted to fake one, it would be possible but cost a lot damn lot of money.
I'd say just the BNR32 on the firewall plate should be all u need to know, other than the obvious signs (RB26DETT, 4WD).
Other than that I guess the same checks you'd do on any other turbo car..cylinder compression level, turbos are holding boost, no strange oil leaks, not blowing too much smoke under boost, full lock turns don't make strange noises, and just in general strange noises.
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
