Sorry for the double post, just wondering whether any other people living in Vic know why. I just got a bit freaked out when for the first time I checked out the prices of these cars in other states...
In Melb our cheapest ones are around the 55k mark whereas in Sydney there are four cars advertised for sale below 50k with lower kms than anything Vic has?!?!?!
WTH's going on here? Is it because NSW is a bigger market? Can't be that much bigger... Melb is only slightly smaller than Sydney, and even cars from WA/QLD are cheaper.
Is it because Vic has the tightest modification regulations so fast Jap cars aren't as popular because they always get defected?
I am seriously thinking about going interstate to buy my car now. 10k is not a small amount of money,which can pay for 80 return flights from Melb to Sydney... jeez.
But it must be a huge headache to do the financial/mechanical checks there, buy it, transfer registration, pay stamp duty, pay for insurance to drive/transport it back, re-register it (and pay another round of stamp duty???).
Has anyone got any experience with this?
It's not really the financial hassle, it's the mountain of paperwork and getting time-off work hassle (as I work a lot of weekends).
Just wondering if anyone had done it and how difficult it was/any problems.
If you are happy to look at the car yourself and be able to decide weather or not it's good and see any problems with it buying interstate is easy. I bought my car from QLD with minimal hassles. As long as they provide you with a current roadworthy rego transfers are easy and you only pay the stamp duty once.
Yep I bought a car from NSW....It is dead easy as long as everything with the car is legit (do the homework) and modifications are kept to a minimum or you are prepared to exchange a few for stocky items as the car has to go through the rego process.
just watch out for the amount of modds..
depends were u get ur road worthys from, they might sting u for everything modded
or they might not.. remeber anything interstate has to got threw vic roads pitlane... so road worthy places
tend to get more tight, even though its only a number plate swap, they still mite check to see if ur car is up to r.w.c standards..
  • 10 months later...
Most of the R34's down there have been touched by Ben at Racepace...thats where the extra $5K comes into play.
Well looked after and well tuned cars = more $$...simple
Edited by DiRTgarage
It's coz they are faster down here in the South, something to do with Mexican food and they South Pole from memory.
So what you are implying is the following:
QLD: Cheapest, slowest
NSW: Moderate, Slightly faster
VIC: Expensive, Fast
TAS: Insane, Extremely Fast
Does that sound about right?
id recomend buying fom nsw as there raodys are more strict than ours if it passed theres it shoul shit in on ours
Wow... a reply from the ancient annals of SAU-VIC. Yeah I ended up buying my R34 GTR from Melbourne... about 10 months ago lol.
Umm... I wouldn't say most. Out of the 15-20 I test drove when I was looking (ie., all of the Vic ones for sale at that point), only 1 had been graced by the touch of the Master. A lot of these are FOB or interstate rides. Although, I have heard that some of the NSW ones, especially from some specific traders have had quite... crash-intensive histories, explaining the unbelievabe low-mid 40k asking price.
Well NZ is likely the most southern country which has Skylines, and we all know that's where Reece McGregor's skyline was born, bred and broke the world 1/4 mile skyline/GTR record.
well i got mine from QLD, lower tax's up there so cheaper cars (one of the reasons anyway). no problems what so ever having it brought down to melb. had the car for 1 week and off to Ben it went.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
