  • Replies 454
Posted Images
Hmm, guess there aren't that many Czech people in Melb?
According to Vplates they can confiscate your plates if they could offend anyone in ANY language. I guess the only way Vicroads will know about plates that got through their filters is if other people rang up to complain.
Anyone heard anything about that rumour of 7-digit plates soon? Or was that an April Fool's joke? The current plates are up to about WFD-### so they have about 1.2 million normal plates left before ZZZ-999 (of course Vicroads will keep that one, but it would be cool to get it).
Have a look at this article for the worl'ds most expensive number plate.
http://carsguide.news.com.au/site/stories/...te_sold_for_15m
"It is not huge compared to my family's fortune,” :/
Damn 20 year old sons of oil barons really have it all in the Middle East. You could buy one of every decent supercar in the world for the amount of money he spent on a wall fixture. I really would like to see his garage.
UAE has huge stretches of long roads, I think there is a straight-as-an-arrow 90-km stretch of road that the oil barons use as their private drag strip basically. You can speed all you want if you're rich :sigh:
i was guna get a 34gtt but instead got 33gtr, but i thought of some plates.
b34st
w34pon
b34tu
b34ten
m34t-AX
lol list goes on
but for the guy with plates for sale 'gdzila' << i think that takes the cake (and eats it)
I saw the plates GODZLA (or similar, but as pretty close to the actual word Godzilla as you can get.)
They were white on green, on some sort of Green 4 x 4. If ONLY they knew......
Also, i hate plates that state the obvious like:
"BLKGTR" ok, thanks for caring, but I AM NOT colour blind.
"MYGTR" Duh, if it wasn't yours, obviously you wouldn't be driving it, but just so we're absolutely clear, you are driving your own car. Congrats.
"LANCER" Thanks for specifying the model of your vehicle, as hard as it is to believe, I am NOT incapable of establishing your vehicle make and model on my own.
Edited by IOWNU
this guy always comes in my street has [PSISUX] on his canary vn/vp. sounds tuff but still :D
lol saw it on sydney rd yesterday looks nice...
wtf are you doin in an SR :)
im a changd man i guess :P na its a "get around car" till my new car hits the streets :D
Edited by nuR.spec
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
