  • Replies 456
Posted Images
I got [V8E4TR] that will go on a 32gtr that I'm building now, had those plates on an s15 for a few moths and took them off after being thrashed by almost every Holden gts lol plus got dobed in on the hoon line a few times as well.
I did originaly apply for different plates but got knocked back and if you check them now in any combination letters and numbers they are unavailable, anyway plates were [DIEYNG] like James deen but Vic roads saw it differently.
  • 5 weeks later...
So I bought I <3 NICK for nothing? :(
soz bro
although there is only one I <3 plate I would get and thats i <3 SOOT cause my car is a dirty diesel
but the colour combo is the worst
[LUVVAG] on a ford in MIll Park...heard this on the fox fm this morning...lolzzz
All the VW's try and get 'VAG' plates
  • 4 weeks later...
driving through Healesville on the weekend and passed a Ferrari meet while they having coffee.
one of them had the number plate: MRCA5H
im sure he requires a hat to prevent his bald spot from getting sunburnt when he cruises in it. which is probably once a year
These plate are from a while ago but i still remember them.
[NYTLYF]
[YBSLOW]
[WRXONX]
[WLDCRD] love those plates. instead of the ones that I have now i was going to get [YLDCRD] but it doesnt look as good lol.
Edited by El_Mutto
[NYTLYF]
[YBSLOW]
[WRXONX]
[WLDCRD] love those plates. instead of the ones that I have now i was going to get [YLDCRD] but it doesnt look at good lol.
the guy who bought my old purple rx7 put the plates YBSLO4 on it, that thing was never fast but it was fun.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
