Make: Nissan Skyline R33
Model: R33 GT-R
Milage: A little over 67,000
Transmission: Manual
Colour: Maroon
Complied?Yes
RWC supplied?No (Cant needs discs)
Currently registered?Yes, till 29th March 2009
Price:$30,000. ono
Contact:Steve on 0409426203
Comments / Modifications: This car is a good, clean stock gtr. The engine was rebuilt around 8000k's ago with foged JE pistons, let me know if you want any details of the rebuild. Needs a new clutch but comes with a Nismo GMAX twin plate thats only done 4000k. Also comes with everything needed to do this clutch install including a Nismo flywheel. Also needs new disks and pads but it comes with a full set of genuine Brembo pads. Has a K&N panel air filter but comes with a HKS pod air filter kit that is close to brand new. The car also has a Fujitsubo Giken cat back exhaust, This is a full titanium exhaust that would cost around $4000 to replace. It has Ohlins coilover suspension all round with adjustable damper. It has an omnitronic alarm that values at $1500 that has remote start and an in car camera that displays photos on the pager alarm handset. It has a 400r front lip and also has genuine R33 GT-R floormats. Stock enterior apart from a near top of the range Pioneer cd/mp3 player with bluetooth. Speaker setup is Rockford fosgate 6" all round with a 600watt pioneer amplifier. Its got a blitz turbo timer and 2x Blitz blowoff valves. Inspections welcomed, let me know if you want photo's. I will have to get them from my computer at home but I have heaps, incuding pics of the rebuild.
Its a fairly stock GT-R with low K's and Maroon is a very rair colour. I have seen more Midnight Purple R33 GT-R's than Maroon. $30,000 ono. Cant go wrong. If you want to swap, let me know the details of what your swapping. I need this car gone because i dont have the budget anymore.
Images:
Edited by steven22
https://www.sau.com.au/forums/topic/212881-r33-gtr-for-sale/
  • 3 weeks later...
Who did the rebuild??
You looking to add money to a swap or get money??
I think unfortunately $25k is more realistic as there are quite a few good ones for $25k, surprising I know but the market is crazy fr sellers, a dream for me:)
Cheers
Nice stock R33 gtr with 53000klms just went on here for 21k
Any interest in swapping for a mint S2 GTST with 80000klms & cash?
Yeah, I'm looking for cash as the big thing though, so I probably wouldn't do your gtst justice. I'm only looking to spend about $12,000 on my new car, so if the gtst is mint it probably will go for more.
Hey, I will swap for a black or silver series 2 R33 gts-t. Dont care if its stock but I want cash on top, or I can take things out of what I am offering, (like the clutch or pods for example) to bring my price down. I'm seriously up for negotiating.
Just something nice & clean guys. Sunroof is a plus.
I would also swap for a: -pulsar gtir
-32 gts-t
Edited by steven22
-32 gts-t
hey man is it still up 4 sale??
how about a 33 4dr, turbo manuak + cash ur way?
cheerd bevan?
When I bought it there was a piggy back chip installed, not to my knowledge. So with its fuel map, my lack of experience with performance cars and the car being fuelled with low ron fuels. Piston 6 was slowly eaten away due to the car running way to lean. When I took it to AVO turbo world after the rebuild, the problem was identified pretty much straight away. I was pissed off, but better to know what happened than to think 'oh well rb26's just blow up sometimes'.
The only way I found out was, one day it had a pretty bad miss so I took it to a mate who was a mechanic, they did a compression test and about 3 months and about 7k later well, you get the point.
This a genuine sale, never been crashed. I need money to pay off a loan. The engine is fine......now. AVO dissabled the chip, checked everything was safe and running ok.
Just to let you know/remind you.
I would swap for a large number of cars, just on the cheaper side cos I obviously need some cash. 180sx's, 200sx's, r32's, r33's, wrx's, evo's. That sort of thing.
Edited by steven22
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
