The last time i used my R32 GTR all worked fine, but today it would not start (it tried to start but no sound from the fuel pump) I checked fuses and connections, all seemed ok. I then hot wired the fuel pump and the engine started and ran as normal but as soon as the hot wire was removed the engine stalled. The only thing that has been changed since the last outing was the instrument pack ??? Any help PLEASE !!!
https://www.sau.com.au/forums/topic/212889-r32-gtr-fuel-pump-not-working/
My R32 had this issue. I just hotwired the pump to the battery and ran a fuse just before the connection. Their is nothing wrong with this. Your pump probably isnt getting good voltage. My pump was getting 9v but my battery output was 14v once I put the inline wire and fuse it worked fine...
Thanks Aaron for your suggestion. I will use your direct wire system. Clive
Thanks Tacker. I took your advice and changed it over with a spare one I happened to have, but its still the same problem. Does the ECU control the pump (the 2 speed thingy) I have a Apexi PFC
Please does anyone else have any ideas on what could cause this problem. I dont think its a low voltage issue. Its more a no voltage issue when the ignition is switched on and cranking the engine over. Thanks for any advice.
very likely to be a problem with the fuel computer if its not the relay. either check the voltage there or just rewire it and bypass the computer like everyone else does.
there is a detailed thread somewhere about fuel pump direct feed re-wire.
There's an ECU that controls the fuel pump - yours has probably died. Same thing happened to my GTR. I opened up the unit and found a dry solder joint and burnt pin. Its located behind the trim on the drivers side in the back seat. It receives signals from the main ECU. There was are "what are these" thread a week ago that had pictures of it. Searchy.
EDIT the thread is HERE top picture
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
