Hey guys,
I plan to drive to qld soon to pick up some parts and enjoy a small holiday, I have a highflow I recently bought and wanted to bolt it on before I head up.
I currently have about 210rwkw with stock injectors, turbo and pump If I bolted on the highflow with the current fueling system and continued to run at the 11-13psi that my stocker runs at would it be just the same on the fuel system and not make the car run lean? I assume it would be the same as its same psi?
Currently the car has a nice smoke covered ass which obviously means its running slightly rich at some stage, mostly when I boot it and on idle Id say from the smell of the exhaust and smoke during booting. I would most likely get it on a dyno to check too but no point unless you guys give me some tips first :(
I just wanted to ask before I went as QLD, is where im heading and its not a short drive.
Edited by DECIM8
https://www.sau.com.au/forums/topic/212900-so-ive-got-a-highflow/
It will be fine but due to the extra flow of the high flow over the standard turbo the tune will be slightly leaner than it was with the stock turbo
I advise you drop the boost down to about 8psi or under instead of the 11 - 13psi your running just to be safe
Other than that its all good just as long as you don't thrash its head off as you can't guarantee that the AFR is at a safe level
11-13 psi on stock turbo does NOT equal same "AIRFLOW" as 11-13psi on hiflow turbo.
Boost pressure does NOT equal same amount of air flow.
if you MUST use the hiflow, just run it off the wastegate spring setting (5 psi or whatever it is).
but then it would be laggy as shit.
^^ unless the engine magically became more efficient by adding a high flow the air flow at the same boost pressure would be equal wouldn't it?
Boost is a byproduct of how much air an engine can flow true? if everything else is the same the engine will only be able to flow the same ammount of air at a given amount of boost ... flame me if I'm wrong :(
In saying that however just leave the stock one on until you get back
Edited by BLK33T
yeah i had to explain that to my dad the other night lol
i was like:
imagine you have a container with 2 small holes air coming in the one side and out the other side and pressure in room is X
now if you make both holes larger you can still have the same pressure of X but it will flow more air :(
Right I see, Well the catch is the stock turbo will be swapped out when I get there for another turbo. So i felt strapping a highflow on and driving up would save the extra effort to remove it.
My current ecu is a Safc piggy back perhaps strap it on run 10 psi or less and drive up there not like im trying to win a race to get there, although that would be a nice run (save some time too)
Oh and dyno it to confirm its not leaning out
i was like:
I never like that analogy, as the engine is a closed system when the pressure is building up against the intake side...it's just the exhaust gas gets out quicker on the higher flowing part. If it was an open system like a jet-engine it would make sense :(
well air comes in the front (air filter) and out the back (exhaust) but yeah...
i just used analogy with dad so he could see the two are not the same :(
Also, what is the diff if I run a Stock AFM or a Z32? Its obviously better at monitoring air but with a safc wont help to much.
Obviously this will change, oh if anyone is after a Safc Neo one will be up for sale from me after i get the PFC
Edited by DECIM8
Obviously this will change, oh if anyone is after a Safc Neo one will be up for sale from me after i get the safc
problem is if you flow LOTS of air stock AFM will max out - Z32 have bigger range...
ps im consfussed your selling SAFC Neo and Getting an SAFC?? As in a SAFC1???????
yeah maxes out and cant read much after a certain reading. "can" cause issues.
e.g.
I had my high flow turbo fitted with standard AFM. I was told to keep boost down because of the AFM maxing out. On the powerFC I wasnt spose to go over 5000 with the air volume read out (forget the correct term?) cause if I did, and if boost spiked a bit, good bye motor.
Got the z32AFM on, now it cannt got over 5000 - most I have had on the track with air flow was like 4600
much safer :D
Hope that kinda explains why, id it doesnt, I fail! :D
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
