Hey guys,
I plan to drive to qld soon to pick up some parts and enjoy a small holiday, I have a highflow I recently bought and wanted to bolt it on before I head up.
I currently have about 210rwkw with stock injectors, turbo and pump If I bolted on the highflow with the current fueling system and continued to run at the 11-13psi that my stocker runs at would it be just the same on the fuel system and not make the car run lean? I assume it would be the same as its same psi?
Currently the car has a nice smoke covered ass which obviously means its running slightly rich at some stage, mostly when I boot it and on idle Id say from the smell of the exhaust and smoke during booting. I would most likely get it on a dyno to check too but no point unless you guys give me some tips first :(
I just wanted to ask before I went as QLD, is where im heading and its not a short drive.
Edited by DECIM8
https://www.sau.com.au/forums/topic/212900-so-ive-got-a-highflow/
It will be fine but due to the extra flow of the high flow over the standard turbo the tune will be slightly leaner than it was with the stock turbo
I advise you drop the boost down to about 8psi or under instead of the 11 - 13psi your running just to be safe
Other than that its all good just as long as you don't thrash its head off as you can't guarantee that the AFR is at a safe level
11-13 psi on stock turbo does NOT equal same "AIRFLOW" as 11-13psi on hiflow turbo.
Boost pressure does NOT equal same amount of air flow.
if you MUST use the hiflow, just run it off the wastegate spring setting (5 psi or whatever it is).
but then it would be laggy as shit.
^^ unless the engine magically became more efficient by adding a high flow the air flow at the same boost pressure would be equal wouldn't it?
Boost is a byproduct of how much air an engine can flow true? if everything else is the same the engine will only be able to flow the same ammount of air at a given amount of boost ... flame me if I'm wrong :(
In saying that however just leave the stock one on until you get back
Edited by BLK33T
yeah i had to explain that to my dad the other night lol
i was like:
imagine you have a container with 2 small holes air coming in the one side and out the other side and pressure in room is X
now if you make both holes larger you can still have the same pressure of X but it will flow more air :(
Right I see, Well the catch is the stock turbo will be swapped out when I get there for another turbo. So i felt strapping a highflow on and driving up would save the extra effort to remove it.
My current ecu is a Safc piggy back perhaps strap it on run 10 psi or less and drive up there not like im trying to win a race to get there, although that would be a nice run (save some time too)
Oh and dyno it to confirm its not leaning out
i was like:
I never like that analogy, as the engine is a closed system when the pressure is building up against the intake side...it's just the exhaust gas gets out quicker on the higher flowing part. If it was an open system like a jet-engine it would make sense :(
well air comes in the front (air filter) and out the back (exhaust) but yeah...
i just used analogy with dad so he could see the two are not the same :(
Also, what is the diff if I run a Stock AFM or a Z32? Its obviously better at monitoring air but with a safc wont help to much.
Obviously this will change, oh if anyone is after a Safc Neo one will be up for sale from me after i get the PFC
Edited by DECIM8
Obviously this will change, oh if anyone is after a Safc Neo one will be up for sale from me after i get the safc
problem is if you flow LOTS of air stock AFM will max out - Z32 have bigger range...
ps im consfussed your selling SAFC Neo and Getting an SAFC?? As in a SAFC1???????
yeah maxes out and cant read much after a certain reading. "can" cause issues.
e.g.
I had my high flow turbo fitted with standard AFM. I was told to keep boost down because of the AFM maxing out. On the powerFC I wasnt spose to go over 5000 with the air volume read out (forget the correct term?) cause if I did, and if boost spiked a bit, good bye motor.
Got the z32AFM on, now it cannt got over 5000 - most I have had on the track with air flow was like 4600
much safer :D
Hope that kinda explains why, id it doesnt, I fail! :D
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
