just dynoed my r32 gtst 5 speed and i was just wondering what power other ppl have and with what mods u have aswell...i drove my car onto the dyno did 3 runs and droive it off diddnt even check timing ... i just wanted to check air:fuel ratio for track day on sunday....
i have 243.6 hp at the wheels on 13 PSI
trust 3 inch cat back exhaust with totally std dump/front pipe and cat
hybrid 600x300x76mm cooler
mines ecu
gtr fuel pump
std turbo
hks power flo filter
thats all that i know of/can remember at the moment....
:P
https://www.sau.com.au/forums/topic/21294-r32-rb20det-5-speed-rwhp-outputs/
Generally the Standard Turbo's won't make any more than 160-170rwkw no matter what other mods you do.
This is 214rwhp-228rwhp.
UNLESS you have a nice little RB25DET turbo hanging off the side then that power is around the mark.
Different dyno's also vary. I've had my car on 2 different dyno's both were Dynamic Dyno's. It made within 5rwkw of each other.
But they were both using the same software version etc.
One was used for dyno tuning almost 100% V8's the other was 100% turbo's etc.
You are making around 181rwkw.
I made 164rwkw on 15psi or 220rwhp.
Its basically the limit of the turbo's as they arn't able to flow much more air to make more power. You can up the boost a little more I guess but then the ceramic exhaust will will probably disagree. :P
Loading her up on the dyno it made full boost (15psi) by around 2500rpm. Or on the street 15psi is 3400rpm in third gear.
the air/fuel was a little rich up top but thats all good...... time for more boost :)....
as far as i know i do still have std turbo but i was told through another person that it had a rb25 turbo installed at one time but i diddnt think it did... maybe i was wrong..... i have dyno sheet that says 243 rwhp so im happy eitherway lol......
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
