  • Replies 410
Posted Images
Ok all my forms are in you should have received one payment of $100 from v_s_p_e_c thats for me. My 2 friends will also send the money through under v_s_p_e_c but will be paying the $130. Is this all good?
Cheers,
Greg
Cheers,
Greg
Thanks Greg, I'll let you know if there is any problems.
Omar.. I have 1 spare seat if you are interested..
I got back seats man...
I'm sure someone will be able to give you a lift... you can probably swap around heaps too, be a little car whore :blink:
Hmmm, back seat sounds roomier lol.
Either way thanks for the offer guys. At least i know i can sign up without an issue :D
Brad - I dont know if I couldnt handle teh powah of teh GTAAAAH!!
But I'll have a go lol Cheers!!!
People are throwing cars at you, I wish they did it for me last year when all I had was the starlet. Mind you, It was alot of fun giving it to the big boys
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
