Not sure if I will be driving yet but Im in for helping!!
Has this been put in Canberra as well??
Need to let the ACT guys know the NSW peeps will be in town :ermm:
Me and Doof on Skidpan duties again :D
Also Helpers will be reward for there efforts... if your not up for driving guys or dont have a car but still want to come we will appreciate all the help we can get!!!
  • Replies 410
Posted Images
I'll have a drive zilch
I was fastest 33 there last time :ermm:
p.s. its not hard to get the licence guys :D
AASA you dont need to be a memeber of an affiliated club like CAMS
CAMS - member of SAU NSW, can get your licence
People, as much as we'd all be stoked that you bring your Skylines, Stageas, Silvias/180SXs/200SXs, etc. along, don't be afraid to bring whatever you have available - one of the quickest car/driver combo's last year was TURISMO in his Aussie-spec EP91 Toyota Starlet, which he COMPLETELY (and I mean COMPLETELY) gutted for the day out on the track.
And Yes, you will need a helmet too! Mainly for the back track, as evil_weevil mentioned...
Yep, if you become an SAU-NSW member, you will benefit from the cheaper entry fee for this and other events - but there are other benefits as well.
Ando, seeing as you no longer have the JapTaxi, are you going to enter your AusTaxi?
Guest
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
