  • Replies 410
Posted Images
Hey all
Considering entering tomorrow morning if there is still space, my license is still good from last year and i'm happy to turn up early. Enjoyed it so much last year!
Unfortunately the clutch is on the way out and I have a few suspension bushes playing up. Given that, I would prefer to run on the wet skidpan and perhaps a couple of runs on the back track (provided clutch holds up).
So just wanted to confirm that the wet skidpan is in? or isn't it? If not i'll probably sit this one out and spectate. Either way see you tommorrow! Looking forward to it.
sorry Leroy, it's the dry skid pan..
we only did the wet one last year cos the stay upright ppl's had taken the dry one on us.
psml at the dildo :thumbsup: good to see my directions to the right places in fyshwick worked out :(
You could have sent them to mitchell. There are lots of porn shops out there and the directions invlolve only 3 corners :(
Guest
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
