  • Replies 410
Posted Images
Hi all
If i were to fill in and send the L2S Cams form by the end of the week do you think i would have it by then and be able to enter this event? :rant:
Cheers Joey
even if you dont you can get a tempery one from them...Think its on the form down the bottom a slip you can tear off
Or could just get your AASA Joey :) both last a year and recongnised at most places
Guest Joeyz
Or could just get your AASA Joey :rant: both last a year and recongnised at most places
Thanks Jess, I'll fill it in and send it off today. Hopefully it wont take 3 weeks
Should I say that I'm in for the day then?
Yep sure can!!
Tear off the 30day licence part at the bottom of Section 4 , Page 4 on the form :rant:
Cams Form : http://www.cams.com.au/downloads/paperform...Application.pdf
Guest Joeyz
Yep sure can!!
Jess
Do i just keep that just incase i don't receive the licence back from Cams and just bring it on the day?
Steve
Please add me to the list and i'll put the payment through by tuesday next week.
Thanks Joey.
Jess
Steve
Thanks Joey.
I need you to send a copy of Cams form to us also so we know you have applied
Now guys, Just to make a note of this.
If you want to apply for a CAMS L2S for this event I would advise to put them in straight away because they can back up and take 2-3 weeks.
Ando, seeing as you no longer have the JapTaxi, are you going to enter your AusTaxi?
Hah ha the VY would bust a nut before the first set of cones.... so no i will quit while ahead... well quit till i get behind another vehicle.. ;) *Chubbs* ;)
Guest
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
