Item:
Tein HA Coilovers - set of 4 to suit R33 GTST. Height and 25 point damper adjustable.
Item Condition:
Excellent condition, just removed from car due to selling. I also have the C-spanners and a set of solid Pineapples to go with them as they are no use to me! No leaks, a very nice set of suspension.
Contact Details:
Contact on my mobile: 0404 80 1900 or PM. Note that I dont get on here as often as I used to so the preferred method of contact is my phone.
Price and price conditions:
$750 negotiable + postage. SOLD
Item:
R33 3 inch stainless steel mandrel bent exhaust.
Item Condition:
Excellent condition, just took it off my car. It is a straight swap for a standard exhaust and bolts up to the stock cat. There are a few scratches on the bottom - as to be expected.
Contact Details:
Again: Contact on my mobile: 0404 80 1900 or PM. Note that I dont get on here as often as I used to so the preferred method of contact is my phone.
$400 $350 + postage.
Thanks guys, any questions ask!
Edited by harvesteros
Hi mate, I think about 20 000, I have done less than 5000. This is going on the kms told to me from the previous owner. I got them checked out before I bought them at a suspension shop anyway, your more than welcome to do so again.
How many KMS on the suspension??
A hell of alot harder.
Thanks mate. Yep they are fairly stiff but not too bad on the softest setting. If you do wind the damper up to full it is rather insane and you do tend to get stuck see-sawing on one front and one back wheel when going into driveways etc. Bit of a hoot.
would the exhast fit a r34 gtt or just r33?
Not really sure on that one but I would not take the risk, im sure they would be different. Maybe someone else knows??
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
