Ok,
For a bout a week my central locking on the drivers side has been shakey. Sometimes it unlocks/sometimes it doesnt - but the key and manual unlocking still works. I pulled off the trim and was examing it. The manual locking and unlocking is fine, however, when the servo (or whatever) tries to push it up looks like it simply doesnt have the force (i can assist it by pulling it up pretty easy). When it tries to pull it down after it hasnt raised fully it makes a wirring/clicking noise as it tries to pull it down after its already down. So I guess I need to replace they pushing/pulling doohicky?
Anyone else had the problem? feedback?
Cheers,
Pen
Maybe its worn, just go to Jaycar and get an aftermarket one..
for starters its new and usually abit stronger too :yes:
in some rare cases your central locking unit could be stuffed and not supplying enough current to the solenoids, due to a stuffed relay or so.
  • 1 month later...
mines bein playing up for awhile now too..
mine unlocks and locks every time thou..
but make's a pretty load buzzing/click sound wen unlocking/locking...
my friend told me to take the door trim of and look just above the door actuator..
there u'll c two bars from the electronic actuator that go to the main bar/rod..
but one bar is connected by a little screw..and next to that is another 2 screws..
all screw are the same size..
he said to adjust the the single screw side..and either move the bar up or down..and adjust till the sound was gone..
he said it solved his problem..of the central locking click/buzzing sound...
though it did not work for me :P
has anyone else fixed this problem before??????????????
If its noisey its the solinoid (thing that does the pushing/pulling) is prolly on its way out. Try disconnecting it from the lock assembly and see if it still makes the noise. If it does you have isolated the problem to being the solinoid. If not you can move the other parts by hand until you find the one thats noisey. :)
Deren
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
