Well i just checked my TPS voltage to try and sort out an idling issue
I've read that it should be around 0.4v closed and 4v fully open
I stabbed the 2 wire plug that comes off the tps with a multimeter and it's reading 10.6v closed, while the car is running:blink:
With the car off it was 9.5v closed and 12.5v open
Am i taking the reading from the wrong place?
Anyone know why it's so high?
On an RB20 by the way
https://www.sau.com.au/forums/topic/212969-tps-troubleshooting/
It misses at idle and fluctuates from 700-900rpm
It misses and jerks a bit when shifting quickly on boost too
edit: There were 2 plugs coming off the sensor, one with 2 wires on the side of it and another one with 3 wires coming out from the bottom of it
I only tested the one with 2 wires, im assuming its the right one because the voltage did change when i opened the throttle
Edited by r32woohoo
iv managed to adjust my tps so it was ideling at a nice level but it still peaks at around 1100-1200 sometimes and other times when i start the car after driving it wont idle properly and will cut out/stall straight away. alot of the time it will fluctuate between 600-900 and cause jerking around 3000 rpm.
im thinking of getting a new tps so i can eliminate a faulty tps and also maybe clean my throttle body too, as i have already cleaned my aac.
other suggestions on the forum is the cold start.
Im guessing, but i think the 2 wire plug is for auto trans. The three wire plug is for the ecu. The only way that it can be above 5v is if there is a wiring problem, or the voltage reg in the ecu has short circuted, which is very unlikely. Unplug the tps, and check the supply voltage, should be 5v
i got some throttle body cleaner and gave it a good clean. started my car and it idled at 1100 and within about 10 sec it bounced to 1500!. i then adjusted my tps so it droped to 1100. took it for a quick drive, to see how it goes with a clean throttle body, and wouldnt idle lower than 2500rpm! after i got going.
mind you it wasnt fluctuating when idleing, probably cause it was idling to high
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
