Heya all,
Finally got my car back on the dyno - This time with more mods and no more LEAN out !!! woot woot !!!
For all that dont know or dont remember.
The last time i had my car on the dyno , was to check my knocking figures i received on my safc...
It was NASTY !!! Even though the car made 180ish kw@wheels . The car a/f was at a 13.0:1 !!! Mods were:
- Greddy Front Mount
- Catback Exhaust
- Pod filter
- Stock Boost
So since then i have done the following mods
- 3" Dump
- 3" Hi-Flo Cat
- CAI
- SAFC2
- Walbro Fuel pump
- Turbosmart bleed - 10psi
Got it back on the dyno and got 160.9kw @wheels. Pretty much wat i was expecting for my bolt on mods. With a little fiddle with the SAFC2. I Gained 20kw @wheelsat topend. Mid range was improved to. Was happy with the results, with only 30mins of tuning. Plus it was a HOT day and the dyno wasnt adjusted for air compensation ect ect. Just raw power figure.
Top end a/f = 12.1
I know a/f curve bit funky. But best i could do with the time i had the dyno. Has anyone got a dyno graph of there a/f with safc so can compare? And also does my dyno look right ?
So im guessing its at 190-200kw @wheels - On a diff dyno , on a good day.
Gettin a Profec B and boosting to 12psi hoping i'll pass the 200kw @wheels mark.
Thanks all for the help and input in fixing my lean out probs!!!
Edited by lilhaulerz
thanks guys !
So was wondering, how much does air compensation and all that, effect the dyno readout ?
Lots ppl gettin 200@wheels wif same mods and boost.
Hot day could prob effect 5kw or so, but still missing 15kw. Does the air compensation factors, change the readout alot ?
More importantly, who really cares?
At the end of the day the dyno can only be used for rough comparison, or comparison between modifications made on the same car on the same dyno on the same day etc if you want to look accurately at differences in power.
Be more concerned with how its driving and performing on the street, if it feels like a good improvements been made then you know you've done something right :laugh:
Yeh, that is tru...
Ultimately at end of the day, car feels heaps faster than 180kw@wheels. very noticable in the midrang - top end. I got super sticky tires in the rears and now manage to fish tail on 1st to 2nd gear shifts and chirps 3rd.
I problem i am having is stoopid boost spike. It spikes to 12-14psi when i get back on WOT on shifts. It pulls back to 10psi quickly but still its a worry. Profec EBC coming soon !!! 12psi flat is wat im aiming for.
Well in reality, if you spend some coin on your ride, its good to know if your getting the same results as others at least. Helps with problem shooting, as unless one knows what 200rwkw 1.5t car feels like, you'd never know otherwise :D
So pissed off now. Once i fix one problem another one arises. I think i got a vac leak or exhaust mani leak somewhere. The car is making a feint whistle sound when i'm boosted like 1-2psi. Goes away later but i think thats just the engine noise overpowering it. Man i hate VAC leaks !!!!
Wats best way to find these things
it's probably a slight leak on your manifold to turbo gasket. I wouldn't worry too much about it at this stage. Once your car starts to sound like it has a jet engine as it comes onto boost, then swap the gasket.
Regarding the power figure, don't worry about it. You're in the ball park. There are guys claiming 220rwkw with stock turbos, i think they are full of shit as are their tuners. You are at the other end of the scale.
Just remember, you don't have full management so your safc tune is going to be a compromise and you have no control over the timing. There's probably more power in it with a stand alone ecu.
Yehh.. That what i was thinking.... even if i boost up to 12psi ... i recon 200rwkw is max i prob get...
Lots of tuners, change ramp speed etc etc just to make customers happy. My figure is pretty raw. But in end of day, its fun to meeh...
Now big qn is.. Should i go for reliability and leave it at 10psi and spend my money else where, or boost it to 12psi and tune again ?
BOOST SPIKE also fixed now.. just a leak in the wastegate to bleed valve line. Although that stoopid whistle is still there. Last nite did notice one bolts on the turbo to mani flange was nearly off, havent tightened it but still whistling, guess gasket must fudge wen the bolt wen loose
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
