Prob with GTR... Auto electrician?
Can anyone recomend a good auto electrician? Im havig probs with the new car and it's really starting to bug me! Yesterday and today I was driving the car around for about five minutes and then suddenly the car would sort of jerk a bit, and then I would loose all rev power and the car would just sit on 1,000 revs and I could'nt moove the car, the needle would just hover between 1&2 revs. It would turn itself off, and then once I restarted it, it would drive fine. The problem happened again today. It feels like a fuel problem or a boost prob, any ideas?
https://www.sau.com.au/forums/topic/21298-gtr-problemshelp/
Mick,
Check both plugs and wiring that is connected to the airflow meters! Usually the top AFM plug insulation becomes brittle near the plug and when it breaks off then the wires can be pulled out of the plug easy.
Sounds like your car is losing function on one of your AFM's (airflow meter), this might be dirty connection, faulty plug, wiring or at the worst faulty AFM. Just check the plugs and wiring first by starting the engine and wiggling them lightly to see if it affects the engine performance, and if it does then its just a plug or wiring.
Hope this helps!!
MEGA
https://www.sau.com.au/forums/topic/21298-gtr-problemshelp/#findComment-450198
