For sale:
1993 R32 GTS-T Type - M (at Tilbrooks dyno 189kw)
5-speed manual
RB20DET (170,000km's)
R33 Series 1 turbo
Custom S/S inlet pipe
Catch can
Trust frount mount intercooler
Greddy BOV
Boost gauge
Re-mapped ECU
R33 GTR fuel pump
3' exhaust with:
AM Performance split dump/front pipe
High flow cat
Whiteline front & rear sway bars
AM Performance Vented coilpack cover
New ISC rear coilovers (height/damper adj)
Tein front coilovers
Front & rear Cusco strut braces
DVD/CD player
R33 floor mats
Re-trimmed steering wheel
New O2 sensor
PM to arrange a time
$11,500
Edited by lows_13
https://www.sau.com.au/forums/topic/212984-r32-skyline-type-m-gts-t/
