Hey.
Got a problem with an R32 GTR. Picked it up from compliance and the idiot decided to jump start it the wrong way. (- to +, + to -). After a bit of smoke he realized, and then jump started it the right way.
The car now will not start on it's own with a battery. We put a working battery out of another car in and no luck. The car will crank once but not have enough power to actually rotate the engine. If we jump start it off another running car, it will start, but only after a good 10-15 seconds of cranking.
The car drives bad. Misfires under any load, and whenever there is a misfire, all the instruments die. The gauges drop to zero, the lights turn off, etc. After driving it around for a while to charge the battery, it will not turn on again after being turned off.
We also tried removing the battery while the car was running to check the alternator, and the car kept running. (Albeit badly, like above)
Anyone have any ideas what may have been screwed up? The car drove fine before the compliance people had their way with it.
Thanks,
Peter
https://www.sau.com.au/forums/topic/213002-r32-gtr-wont-start-without-jump/
lol omfg get the guy to pay for the damages...but i doubt its the ecu
btw why did the guy try jump starting it anyway? if it started fine before?
Edited by 10MinuteCar
It took him 2 months to comply it. By that stage, I guess the battery had gone flat.
if he used a jumper pack they require load in order to work, starting this backwards still provides load, imo he prob fried the ecu hence ur intruments die, ur misfire underload is ecu related because the ecu isnt able to correspond to input given by ur sensors eg. crank, temp etc etc therefore not supplying enuf fuel under load. ide prob get it swapped with a working one to test it, this is ur easiest option.
check out the earth connections on the battery terminals and on the block where the main earth is bolted on
Off the top of my head im pretty sure its on the driver side engine mount
May be loose
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
