Guest INASNT
Originally posted by R31Nismoid
You forget what you posted?
:) ok!
i just hope r34gtt didnt buy the kit from that james guy in st albans who trades under the name option house performance coz the turbo looks legit but he does hes own welding and sells em off as hks, apexi and other jap brand stuff!!
  • Replies 64
yeah i bought in st albans but wasnt off OH performance.the bloke i got it off bought it off him 3 months ago.apparently brand new for 9k. yeah that prick is dodgy as, been there before and ran away.when you see the manifold you will know its a nice one definaltely machine welded me reckons.has slots machined out to prevent cracking and shit.im stoked with what i got. all in perfect nick and very high quality.
ps: when i went to OH he had cast hks end tanks and was welding em onto el cheap o cores.
pss : 3037s are ball bearing or bush bearing???
psss: turbo is high mount turbo will be a tad higher that rocker cover
Guest INASNT
yes that option house guy is a dodgy ****! I just asked coz i other i know seen an similiar add for 3037 kit and he contact number was his. I gotta check out this manifold when i get back to mel
when this turbo comes on boost will depend on which exhaust housing he is running. given that the engine is an RB25DET and that they flow quite well as they are, the turbo shouldn't be too laggy.
nice package dude, good luck, it should serve you quite well.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
