300 RWKW using the GT-RS
I think the one you are thinking of is 'thizzle' he was one of the first guys in AU to get the GT-RS
it was setup at BD4's from memory and it made a touch over 300rwkw with cams and other junk
since then no one else has come close to that mark - im not saying its bullshit or not, but average GT-RS is around 260-270rwkw
there's a few other "high scorers" some that come to mind;
grepin's 2835 setup
thizzles GT-RS setup
again - it doesnt mean the figures are bogus, they are probably legit
but i suspect there some info from the puzzle missing, theres always a reason a car makes more power etc.
you dont make extra power from magic dust or magic tricks.
Interesting discussion guys. I agree with SK that boost isn't what determines horsepower. The formulas are good indications of likely power with standard aftermarket mods, though each car's setup can have so many variables the formulas can't be taken as any more than a guideline.
Certain mods (like cams) will shift an engine's powerband around depending on the setup the owner wants, so this can throw off the calculations as the maximum power at a certain boost pressure will be higher/lower than the same turbo on stock cams. Setups like these would obviously be classified as outliers in graphing power vs boost, so that will automatically distort the formula depending on whether you keep the outliers/disregard them.
There are too many variables to generalise RB25 power levels IMO. But the formulas come very close, closer than an estimate at any extent.
I think your right on the money, i got my 34 dynoed today and i got 240.6kw atw on 15psi. Unfortunately i ran out of fuel as im still waiting on my injectors to come. Ahh well, the gt-rs is a sick turbo, i get full boost at 3200!!!
Hi guys,
I conducted a regression analysis using the output figures and boost ran from the dyno thread relevant to the RB-25 engine with a HKS GT-RS Turbo.
Basically, a regression analysis is a form of statistical modelling that attempts to evaluate the relationship between one variable (Boost - PSI) and another (Power output - RWKW).
This data will help you 'predict' what sort of power you would get if you have an R33 GTS-T (RB-25 engine) with a HKS GT-RS turbo and other supporting mods of course (ie. Front Mount I/C, Full exhaust, Fuel pump etc etc) running the boost of your choice.
Basically, select the amount of boost you wish to run, and look at the corresponding output figure next to it for an estimate of how much power you would be making.
This analysis is ONLY a rough guide, please do no use it as a definite determinant since all cars are individual and differ to one another.
This post should eliminate those repetitive questions such as; 'How much power will I make if I run XX amount of boost with a GT-RS turbo on my R33?'
Cheers!
  • 2 months later...
Nice turbo, just finished tuning a customers car silver SII r33 277rwkw @ 1.1bar which is bit of a suprise as it was bought from the auctions as an unknown.... turns out to be a stolen and recovered jobbie with full whiteline and bilstein handling kit, 555cc injectors, PFC (i had one laying around) and hybrid cooler... and of course a HKS GT-RS
it is almost identical in response to a 8cm T67 kit i did for a customer awhile back but is a little short on top end.
interesting topic...
i just got my car back today with a 2835 pro s (.68) and its making 265 @ 19psi ... click for more detail
bombtrack has a neo gtt with EXACTLY the same mods as me but with tomei cams and will be getting his done soon on the same dyno / tuner
will post results when it happens
Wow at only 1.1bar? That's pretty impressive. Why didn't u run a bit more boost through it, surely it would have still made a bit more power at around 1.3bar...
Yeah, the customer asked for the best result i could get a 1.1bar so i did what i could, it definately would run bigger numbers easily but he's happy :D
grepin's 2835 setup
http://www.skylinesaustralia.com/forums/30...es-t151839.html
I just looked at the dyno chart in that Grepin thread... 322rwkw with sub 10:9 air fuel ratios!?! something not quite right there
would love to get 300rwkw out of the 2835... pointless on the street but would be heaps of fun on the track... I don't think it would quite get there tho
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
