HAS ANYONE OUT THERE WITH A R34 GTT HAD ANY ISSUES FITTING THE HKS SSQ IN THE SAME SPOT THE FACTORY BOV IS?
MY TUNER MENTIONED ITS NOT A SIMPLE BOLT ON, EVEN WITH THE ADAPTER FLANGE. APPARENTLY HE NEEDS TO CUT HERE AND WELD THERE, HE IS STRONLGY RECOMENDING AGAINST PUTTING IT IN.
HAS ANYONE HAD PROBS FITTING?
CHEERS
https://www.sau.com.au/forums/topic/213137-hks-ssq-bov-install-probs/
CHEERS
Ive got one fitted in my car, there's NO welding required, as it is a simply bolt on the factory pipe along with
the correct adapter plate attached.
DID IT GET IN THE WAY OF ANYTHING? APPARENTLY MINE IS? ALSO, I HAVE THE ADAPTER KIT TO FIT STRAIGHT ONTO MY ORIGINAL FLANGE,
DID YOU GUYS PLUMB IT BACK ?
Apparently yours is?? is that where you thinking, or is that what you've been told.
Post a pic mate, I didnt plumb back, it runs fine :/
MY TUNER MENTIONED HE WOULD PUT MY BOV ON FREE OF CHARGE AS LONG AS IT WAS SIMPLY A BOLT ON JOB AS I AM ALREADY PAYING 2,500.00 FOR A POWER FC, WALBRO PUMP + LABOUR.
HE RANG ME LAST NIGHT AND MENTIONED THAT IT WASNT GONNA BE AS SIMPLE AS BOLTING ON SINCE HE INSISTED WE PLUMB IT BACK. HE SAID THE BOV ITSELF HAD NO ROOM TO FIT AS A DIRECT REPLACEMENT FOR MY FACTORY BOV AND THE HKS PLUMB BACK EXTENSION WASNT LONG ENOUGH TO CONNECT WITH MY PIPE LEADING BACK TO THE ENGINE.
HE WAS PRETTY MUCH TELLING ME ITS WAS GOING TO NEED WELDING, FABRICATION, CUTTING, ETC. HE PRETTY MUCH TOLD ME TO FORGET ABOUT IT. I CANT FORGET ABOUT IT AS I HAVE JUST FORKED OUT ALMOST 400 BUCKS ON THIS BLOODY BOV AND I WANT IT ON MY FRIGGIN CAR.
IM NO MECHANIC BUT IS FITTING THE HKS BOV ON MY GTT SOMETHING I COULD DO MYSELF? I DID REPLACE MY FACTORY AIR FILTER WITH A POD FILTER MYSELF SO IF I WAS CAPABLE OF THAT SHOULD THE BOV BE SIMILAR IN FITTING?
THANKS BOYS.
as long as your engine bay is stockish then there should be no problem what so ever. There's the adaptor plate, the rubber o ring to go on the BOV and the little circlip that holds everything in place. 2 minute job putting it on. Pic of engine bay would help/.
ahh i think i see wat your trying to do mate. u want to plumb it back. DONT BOTHER. that is a bitch, and at the most all it would take is the plumb back adapter and maybe half a foot of 1'' rubber hose.
anyway. if u just block off the stock return pipe, and bolt on the ssq with the adapter. it will take about 15min. take out 2 bolts, take off stock bov. block return pipe. stick on bov with adapter and stick in the 2 bolts. thats it. i really dont see how its that difficult. i might suggest that your so called 'tuner' either doesnt know shit all. OR he has seen u coming a mile away. and would like to make a quick buck.
adapter shud look like this
http://cgi.ebay.com.au/Skyline-GTS-BOV-ada...bayphotohosting
Edited by r33cruiser
hey thanks for the info guys. I think R33Cruiser is on the same page as my "tuner", the plumbing back side is whats causing the apparent massive headache.
Either way we've given the BOV install a miss this time round, but when i get the car back tonight, i will have a look and try and swap my stock BOV with the HKS BOV. I do have the adapter you are referring to with the BOV.
but with blocking the return pipe, whats a good way to do this? as I will attempt to swap BOV's myself tonight.
Edited by CK34GT
Hey how r ya, Its really eas to install, no cutting or welding is needed, ur tuner probably thought it was the universial one, wot u need is an adapter! its just a simple bolt on, And you also have to block your plumback with a metal thingy.. mine came with it.. Tough sound but car doesnt run right unless u tune it, ur car will run rich and will stall sometimes.. that is just my 2cents from wot ive learnt.
Geraus.
CK34GT get a pic of your engine bay near your throttle body, its a freakn 10min job and shouldnt hard at all.
even if u wanna plumb it back it is easy as piss, as long as you have the plumb back adapter.
if you dont have anything and jsut the BOV, then yes its gonna be a pain.
if ur unsure like i said post a pic ive done it before
SIF 10 min job.... dont tell him its 10 minutes, he starts to panic after 10 minutes....
i just install it yesterday.
YES i agree with you, theres a hose which is connected to your boost reading for the stock boost gauge in the car, u can just fit the ssqv in an angle around 30 degrees.
you do not need to fit it in horizontally, just give it a twist b4 installing it into the current position.
all you need is an adapter from ebay. works fine n quality is not bad.
Hi All,
Ok I got the car back last night. By the way the Power FC makes such a massive difference.
Anyways back on topic. I have taken a few snap shots of my engine bay as is and my new BOV accessories.
I have a pretty good idea what to do.
Any advise let me know what you think.
Thanks heaps.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
