HAS ANYONE OUT THERE WITH A R34 GTT HAD ANY ISSUES FITTING THE HKS SSQ IN THE SAME SPOT THE FACTORY BOV IS?
MY TUNER MENTIONED ITS NOT A SIMPLE BOLT ON, EVEN WITH THE ADAPTER FLANGE. APPARENTLY HE NEEDS TO CUT HERE AND WELD THERE, HE IS STRONLGY RECOMENDING AGAINST PUTTING IT IN.
HAS ANYONE HAD PROBS FITTING?
CHEERS
https://www.sau.com.au/forums/topic/213137-hks-ssq-bov-install-probs/
CHEERS
Ive got one fitted in my car, there's NO welding required, as it is a simply bolt on the factory pipe along with
the correct adapter plate attached.
DID IT GET IN THE WAY OF ANYTHING? APPARENTLY MINE IS? ALSO, I HAVE THE ADAPTER KIT TO FIT STRAIGHT ONTO MY ORIGINAL FLANGE,
DID YOU GUYS PLUMB IT BACK ?
Apparently yours is?? is that where you thinking, or is that what you've been told.
Post a pic mate, I didnt plumb back, it runs fine :/
MY TUNER MENTIONED HE WOULD PUT MY BOV ON FREE OF CHARGE AS LONG AS IT WAS SIMPLY A BOLT ON JOB AS I AM ALREADY PAYING 2,500.00 FOR A POWER FC, WALBRO PUMP + LABOUR.
HE RANG ME LAST NIGHT AND MENTIONED THAT IT WASNT GONNA BE AS SIMPLE AS BOLTING ON SINCE HE INSISTED WE PLUMB IT BACK. HE SAID THE BOV ITSELF HAD NO ROOM TO FIT AS A DIRECT REPLACEMENT FOR MY FACTORY BOV AND THE HKS PLUMB BACK EXTENSION WASNT LONG ENOUGH TO CONNECT WITH MY PIPE LEADING BACK TO THE ENGINE.
HE WAS PRETTY MUCH TELLING ME ITS WAS GOING TO NEED WELDING, FABRICATION, CUTTING, ETC. HE PRETTY MUCH TOLD ME TO FORGET ABOUT IT. I CANT FORGET ABOUT IT AS I HAVE JUST FORKED OUT ALMOST 400 BUCKS ON THIS BLOODY BOV AND I WANT IT ON MY FRIGGIN CAR.
IM NO MECHANIC BUT IS FITTING THE HKS BOV ON MY GTT SOMETHING I COULD DO MYSELF? I DID REPLACE MY FACTORY AIR FILTER WITH A POD FILTER MYSELF SO IF I WAS CAPABLE OF THAT SHOULD THE BOV BE SIMILAR IN FITTING?
THANKS BOYS.
as long as your engine bay is stockish then there should be no problem what so ever. There's the adaptor plate, the rubber o ring to go on the BOV and the little circlip that holds everything in place. 2 minute job putting it on. Pic of engine bay would help/.
ahh i think i see wat your trying to do mate. u want to plumb it back. DONT BOTHER. that is a bitch, and at the most all it would take is the plumb back adapter and maybe half a foot of 1'' rubber hose.
anyway. if u just block off the stock return pipe, and bolt on the ssq with the adapter. it will take about 15min. take out 2 bolts, take off stock bov. block return pipe. stick on bov with adapter and stick in the 2 bolts. thats it. i really dont see how its that difficult. i might suggest that your so called 'tuner' either doesnt know shit all. OR he has seen u coming a mile away. and would like to make a quick buck.
adapter shud look like this
http://cgi.ebay.com.au/Skyline-GTS-BOV-ada...bayphotohosting
Edited by r33cruiser
hey thanks for the info guys. I think R33Cruiser is on the same page as my "tuner", the plumbing back side is whats causing the apparent massive headache.
Either way we've given the BOV install a miss this time round, but when i get the car back tonight, i will have a look and try and swap my stock BOV with the HKS BOV. I do have the adapter you are referring to with the BOV.
but with blocking the return pipe, whats a good way to do this? as I will attempt to swap BOV's myself tonight.
Edited by CK34GT
Hey how r ya, Its really eas to install, no cutting or welding is needed, ur tuner probably thought it was the universial one, wot u need is an adapter! its just a simple bolt on, And you also have to block your plumback with a metal thingy.. mine came with it.. Tough sound but car doesnt run right unless u tune it, ur car will run rich and will stall sometimes.. that is just my 2cents from wot ive learnt.
Geraus.
CK34GT get a pic of your engine bay near your throttle body, its a freakn 10min job and shouldnt hard at all.
even if u wanna plumb it back it is easy as piss, as long as you have the plumb back adapter.
if you dont have anything and jsut the BOV, then yes its gonna be a pain.
if ur unsure like i said post a pic ive done it before
SIF 10 min job.... dont tell him its 10 minutes, he starts to panic after 10 minutes....
i just install it yesterday.
YES i agree with you, theres a hose which is connected to your boost reading for the stock boost gauge in the car, u can just fit the ssqv in an angle around 30 degrees.
you do not need to fit it in horizontally, just give it a twist b4 installing it into the current position.
all you need is an adapter from ebay. works fine n quality is not bad.
Hi All,
Ok I got the car back last night. By the way the Power FC makes such a massive difference.
Anyways back on topic. I have taken a few snap shots of my engine bay as is and my new BOV accessories.
I have a pretty good idea what to do.
Any advise let me know what you think.
Thanks heaps.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
