If someone could please post a pic of their R34 GTT engine bay with the HKS SSQ fitted, that would be unreal. I could just follow your lead.
Thanks heaps for all your help people.
CK
Edited by CK34GT
okai CON heres the rundown.
you have 2 options.
Option 1 is ATMO = atmo just required you to remove "BOV" (see picture below) and replace it with the SSQV, aswell as pluggin the original Vacumm hose(see pic) into the SSQV BOV ONLY IF YOU HAVE THE ADPATER TO SUIT YOUR CAR!!!!!
if you dont have the adapter.......welding is required which = more time = more money
Option 2 is Plumb Back = same Process as option 1 but you will require a PLumb Back Kit (official term by HKS is called a "Return Nipple") if you have this its pretty much a swap and plug n play.
If you dont have the return Nipple and your want your bov to be plumbed back, youll need to modify your exisiting plumb back system to suit the ssqv, which can be a long process.
are you in melb con? if u are let us know pop around sometime ill get it fitted for ya.
in the above picture, the black hose is a "VACUM HOSE" supplied with your HKS BOV.....it is recommended that you use this one because its newer, but you can use the one thats still on your car =]
any questions dont hesitate to ask
Edited by R34NRG
thanks heaps Andrew, i figured thats what i had to do. Im in Sydney actually but thanks for the offer.
One last thing, you see the black spin top looking piece in the plastic bag.... whats that for?
U use that plastic bit to cover the return plump back. IF your not plumping it back.
Its a filter :devil:
my hks ssq was a striaght bolt.. reason is, i didnt plum back... undo both bolts on stock bov, remove bov, dis connect the plum back hose, plug with that black bung you got in the plastic bag, tighten up the hose clamp around the bung, bolt on hks ssq, small vacuum line goes into the little ufo lookin thingy...lol... other hose connects directly to the bov... peace of pish!!
Btw i have a 34 just in case you were wondering!!
HAY GUYS THANKS AGAIN FOR ALL YOUR INFO, I FITTED THE BOV LAST FRIDAY AND ITS WORKING WELL.
I LEFT IT ATMOSPHERIC AS THE OFFSET BETWEEN MY BOV AND RETURN PIPE ARE ABOUT 2 INCHES OFF.
I HAVE TO SAY THAT I FELT AN IMMEDIATE POWER DROP SINCE FITTING THE HKS BOV. UNTIL I AM READY TO PLUMB BACK MY HKS I AM CONSIDERING TO PUT THE FACTORY BOV BACK ON SO I CAN GET THE AIR CIRCULATING AGAIN.
DID ANYONE OUT HERE ALSO FEEL A DROP IN POWER WHEN FITTING AN ATMO BOV?
lol yeah it should even slightly increase ur turbo response apparently. but i know for a fact ur car will run crappy (as in not smooth) with atmo bov cuz mine does it :blink: but not with stock ones but still it doesn't drop power or boost
Edited by R33Turbo
If it's sound you want, I wouldn't install it onto your R34 GTT as the HKS BOV won't give you nice sound until you run a bucket load of boost through it...
Again...thats a load of absolute BS...we have told you before that you DO NOT need high boost on this bov to get that sound...it just needs some adjustment...and if it still needs very high boost to open...the BOV is faulty...
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
