Intercooler Cheat ;)
By funkymonkey · Posted
They were. I bought the AWD for experimenting but racing it would disqualify or disadvantage me from a few race classes. Def getting a FWD for racing. -
Hey guys does anybody know the part number for an ER34 4Speed automatic 25GT speed sensor? Can’t find anything online for automatic. Trying to troubleshoot non-working speedometer and was wondering how much they cost if it turns out it’s bad when I get to it.
Hey Murray, hope all is good. I took your advice and put the filler first then the putty. Seems like a much better result but i noticed there are still pinholes. I even had pin holes when i initially put the putty on the body filler. Do you think it has something to do with my spreader being f*cked? I attached some images. This is the intially body filler i sanded. No putty yet Applying putty. Final result after using wax and grease remover can see the pin holes. I just noticed as i look at the putty application it looks wavy not sure if it's supposed to be like that or because of the spreader.
By Julsmadrid · Posted
Hey all just wanting some advice. I’ve just compression tested my RB25det and these are the following results Cyl 1 - 135psi Cyl 2 - 135psi Cyl 3 - 120psi Cyl 4 - 140psi Cyl 5 - 130psi Cyl 6 - 125psi do these numbers seem ok. Thanks in advance -
I must say - this is how I picture all R31s!
