sup people..
one my m8s (into racing rally cars)told me that in the evos 7 they use they create anotha pipe coming from window washer motor and connect a jet/mister( like window washer ) and aim it to the intercooler to cool the intake air temp. this is controlled by a solinoid valve so u can still use your window washers:)
they recon the can feel a difference because every kw counts in rally as not aloud 2 many mods:s
gunna try it soon c how i go
reply, tell me what you think:)
cheers
https://www.sau.com.au/forums/topic/213146-intercooler-cheat/
very common, the evo 8 and 9 have it standard i believe
there are aftermarket kits available also
to try it out
1. blow air from your mouth on your hand - note its hot
2. wet or lick your hand (the same spot)
3. blow air from your mouth on your hand where its wet - note its cool
the water undergoes some thermal change and does a big temperature drop
if you do the same on the intercooler core, it drops the temperature in the same way
sup people..
cheers
lowering your in take temps is always a good thing.
not sure if you will be able to feel the difference. on some hot days it will feel less sluggish
Old schooool
Specific heat values...
Air ~ 1 kJ/( kg * deg K)
Water 4.18 kJ/( kg * deg K)
...and with a latent heat value of 2256 kJ/kg, the evaporation process removes a fair deal of heat.
As to if you'll feel it? Well its like most things. If the ambient air is dry, your moving quickly and the IC is already fairly saturated (like dan said) then sure, it'l make some noticeable difference.
PS: Licking my hand got me hot.. not cool ;)
Edited by GeeTR
How many KW did it give you?
dude hes talking bout not licking his had coz he just had a toss lol
thanx 4 the info boys
im gunna buy the stuff 2 morro
ill take pics nd tell u how it goes
cya's
cya's
Don't forget to toss before you test it out.
Oh, and post pics too. Of the waterspray. The one on the car.
rofl intercooler spray. have a look on youtube.
I NEVER saw any change when i had mine. i had 4 misters and used my old stock fuel pump as the water pump.
unless you are a track hoon and out there every waking moment, theres no need. an effective cooling system that is maintained will do a better job.
i ended up caning mine. waste of time. bit of a wank factor too
Edited by r33cruiser
sup people..
cheers
Is called Heat Soak Evaporation.
By spraying water on the intercooler while the car is driving forward and the air is blowing towards the intercooler, its basicaly "chills" the it, gets rid of the heat and makes the air colder going into the inlet plenum.
You can program the water jets to start sparying when the car hits boost.
But with all the water restrictions we have you better have a good sorce or water. LOL!
Edited by (00)SKYLINE(00)
thought i might add my 2c:
when i fill up at the local servo on a hot day.. pop the hood and pour water from those containers over the fmic and the radiator while the engines running..
when i start driving i notice that the temp gauge on my cluster R33 25t drops a fair whack.. it remains like that for around 15-20 min or so.
i dont think a wee bit of spray would make any noticable difference at all, unless you let it spray for like 1 min continuously so that the fmic is drenched.
Lol.
Has any one sprayed that Loctite freeze and release spray onto their intercooler and noticed a difference? We sell it at work and have always thought about giving it a shot, ment to cool it down to negative temperature, kind of like a Nitrous intercooler spray only a lot cheaper lol.
Here's the stuff im talking about:
http://www.loctite.com.au/int_henkel/locti...elease_red5.jpg
Surely something like this you would notice a BIG difference if some people reckon they can feal a water spray kit work.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
