Lol.
Has any one sprayed that Loctite freeze and release spray onto their intercooler and noticed a difference? We sell it at work and have always thought about giving it a shot, ment to cool it down to negative temperature, kind of like a Nitrous intercooler spray only a lot cheaper lol.
Here's the stuff im talking about:
http://www.loctite.com.au/int_henkel/locti...elease_red5.jpg
Surely something like this you would notice a BIG difference if some people reckon they can feal a water spray kit work.
you know, thats not a bad idea at all
would prevent heat soak through the burnout stage
Yeah, ive always thought about it, had a look at work but we are all sold out dammit! If i remember right, it freezes it to like -10/-20 degrees or something. Surely spraying this on your cooler would have some good results. Was thinking about doing this in the next dyno comp to see how it goes.
on the bottle is says -43 or something in that range the stuff works well for bolts to LOL jam it in the hot pipe and spray under boost the would make a huge difference would sorta be like water injection,
Freeze a room temp bolt is different to cooling something like an intercooler. A single can wouldn't do dick me thinks
Rem to search gentle'ladies, theres been some good talk on SAU :P
If you were going to try something more expensive then a basic IC spray, i would have thought a C02 sprayer would the first option.
Linky
BOC must sell 10lbs refills fairly cheaply.
Edited by GeeTR
Anyone ever looked into metho spray? screw window washing metho dries at a cooler temp than water. :D However does leave some residue, perhaps a metho/water/soap mixture could be made to clean, cool and spray :D
Edited by DECIM8
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
