selling all parts series 2 r33 skyline gts-4 model silver auto
current avilable
boot lock with key
boot struts
rear windscreen wiper
tail lights with skyline garnish
rear bumper
wiring loom, including antenna, taillights, license plate light, spoiler LED lights
RH front guard with indicator, missing gt badge
boot lining
rear spoiler with full working LED lights, damaged
set of skyline mats
driver and passenger seats
anything off dash
steering wheel with airbag
battery bracket
side skirts left hand side cracked at back
2 tyres 95% tread 4 stud
anything else just ask
https://www.sau.com.au/forums/topic/213158-r33-parts/
current avilable
boot lock with key
boot struts
rear bumper
boot lining
set of skyline mats
anything off dash
battery bracket
so ur selling body loom, not engine?
https://www.sau.com.au/forums/topic/213158-r33-parts/#findComment-3765137
current avilable
anything off dash
Hi Mitchell,
How much are you asking for the seats?
Can you describe the material colour and any patterns if applicable.
And do you have the centre console lid with an unbroken release 'lever' (in the usual dark grey vinyl of course).
Cheers
Martin
https://www.sau.com.au/forums/topic/213158-r33-parts/#findComment-3765405
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
