Hi guys,
I've organised a Dyno Day for some friends of mine that will be held at C&V. Currently we have 20 cars and we are looking for another 5 cars.
If we get 25 cars the cost of each car is only $40. This includes 2 passes with printouts (you can run two setups obviously like low boost or high).
The dyno at C&V is a Dyno Dynamix so you can run 4WD, RWD or FWD.
This is probably the cheapest dyno you'll ever do..... however, I am only looking for 5 cars so first in first serve.
Cheers
https://www.sau.com.au/forums/topic/2132-cheap-dyno-day-sydney-17th-aug/
  • Replies 47
400HP: hey dood have you found ur five ppl yet??
I got a fairly new stock R33, and i just wanna run it up on dyno for checkup purposes...like fuel mixtures and so on ...
If you prefer to have high power runs well then i cant really help you there..
but let me know
thankx
mc
:shake:
Hype - cool thats fine I'll reserve a spot for you tentatively.... when can you let me know for sure?
soopamarcus - yep there's still place... does not matter how stock your car is its fine.... its not a dyno shootout... its just a day for people to get cheap dyno print outs (which C&V usually charge a lot more for)... you just have to tell me if your definite cos I'll book you in..... btw you don't happen to go to UNSW do you?
In regards to the air/fuel I have talked to Con at C&V today. As you get two passes you can do a power dyno and also a air/fuel one so you can map the two together and see how the a/f ratio affects your power.
So to answer your questions (Xrsist & Majanal) - yes you can get these printouts.
I have confirmations from many people now. As I mentioned that the numbers are limited and I do not want any pull outs before the day. I would prefer payment beforehand for the day (its only $40 for the day as i mentioned). I have the following Sky. Aust. people as interested:
- Hype
- soopamarcus (confirmed)
- Majanal
- XrSiSt
- trza2k x 2
I will PM you guys my number (if I haven't already talked to you). First in best dressed.
Cheers
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
