  • Replies 47
Guys.... as I posted in NSW section the places for this have filled up so unless you have confirmation from me then there's no more positions. I have given a cutoff date for pullouts as next Monday so if anyone does pull out I will let you guys know ASAP.
These are the SA attendees:
JiMBO (R33 Skyline GTS-T)
Soopamarcus (R33 Skyline GTS-T)
Majanal (R33 Skyline GTS-T)
trza2k (S15 200SX)
trza2k's friend (R32 Skyline GTS-T)
Xrsist @ SA (R33 Skyline GTS-T)
Cheers
Originally posted by 400HP
Hi guys,
I've organised a Dyno Day for some friends of mine that will be held at C&V. Currently we have 20 cars and we are looking for another 5 cars.
If we get 25 cars the cost of each car is only $40. This includes 2 passes with printouts (you can run two setups obviously like low boost or high).
The dyno at C&V is a Dyno Dynamix so you can run 4WD, RWD or FWD.
This is probably the cheapest dyno you'll ever do..... however, I am only looking for 5 cars so first in first serve.
Cheers
400HP, What time do we have to be there.
Anyone got the address?
DYNO DAY DETAILS
Date: Saturday 17th August
Place: 34-36 O'Dea Ave Waterloo (call me if you need directions).
Time: Con has stated that cars should be at the venue no later than 9am (PM me if this is a problem). However you may have the opportunity to run your car till later. I think it will most likely be first come first serve unless you arrange with me beforehand.
Cost: $40 (please bring $50 because if lots of people pull out it will be this much. Sorry about that but I think we'll have fill ins on the day anyway).
C&V's TERMS (which they have stated to me verbally.. but these are pretty standard and quite acceptable terms)
- All cars are to be parked at the workshop outside.
- Please do not enter the workshop and walk around because there are other customer's cars there.
- DO NOT enter the Dyno area unless you are given permission to do so as it is dangerous.
- When its your cars turn to dyno your car will be driven into the workshop by a C&V staff and the dyno run will be run by C&V staff.
- No responsibility will be taken by any of the C&V crew on damage to cats which could occur on the dyno (now this relates to engine and mechanical failures.... obviously if C&V do not strap your car down properly or do something which is obviously their fault they are probably liable...)
NOTES
Could these people please let me know their time preferences...
AND if they are content to do just 1 run.... you can do 1 or 2 but please only do 2 if you are going to change something... all 25 or so cars will do one run before anyone does their second run.
trza2k (S15 200SX)
trza2k's friend #1 (R32 Skyline GTS-T)
trza2k's friend #2 (R33 Skyline GTS-T)
Xrsist (R33 Skyline GTS-T)
Thanks
400HP,
I would like to do two runs, one at a low boost setting and one at high boost to measure the differences in air fuel ratio's.
I may have a problem though as the tyres that I have orded have not arrived yet. Do C&V have any problems with tyres with very little tred?
Please call me on 0414 940 938 if there is any difficulties. otherwise I'll see you on Saturday.
Cheers,
Dan.
Well, I'm home.
Had a good day and was plesently supprised at the out put of my car. Was also good news to find out that my air/fuel ratios are good.
Must take this opportunity to thank Yang for organising it all. Good job mate, the day ran really smoothly.
Was good to catch up with some people that I haven't seen in a while, and some that I saw recently. Also good to meet some new people as well.
Run of the day has to go to pete in the barina!
Take care all,
Dan.
Guys.... thanks for coming. It ended up being a great day with a good mix of cars. Here are the results which I have split into interesting categories.
OVERALL POWER
Nick RH9 (R33 Skyline GTR, Highly modified) 290kw @ all 4 wheels
Andrew (R33 GTS-T, Highly modified) 263kw @ rw
NICOT (E36 M3 Convertible) 157kw @ rw without exhaust, 173kw @ rw with exhaust
BLOWN3 (Turbo 318is) 170kw @ rw
Majanal (R33 Skyline GTS-T) 162kw @ rw with 0.9 bar, 141kw @ rw with 0.55 bar
SERGE (E36 M3) 153kw @rw
Yang (Skyline GTR) 150kw @ all 4 wheels
Scott (S14 200SX) 141kw @ rw
Xrsist (R33 Skyline GTS-T) 140kw @ rw
Roland (Porsche Boxster-S) 140kw @ rw
Joe (R32 Skyline GTS-T) 130kw @ rw
Marcus (R33 Skyline GTS-T) 130kw @ rw
Andrew (S14 200SX) 130kw @ rw
Henry (R33 Skyline GTS-T) 127kw @ rw
Daniel (S15 200SX) 120kw @ rw
RONIN (Turbo MR2) 115kw @ rw
Ken/Kelvin (Supra SZ) 108kw @ rw
2FLYBY (Alpina 2.7L) 103kw @ rw
Bob (Mercedes ML320) 101 kw @ all 4 wheels
Rob (MY01 WRX) 100kw @ all 4 wheels
M PWR (635csi) 95kw @ rw
Marcus' friend (Integra Type-R) 85kw @ rw
StygiaN (MR Lancer) 62kw @ rw
ULTIM8DTM5 (Corsa) 45kw @ rw
TURBO
NATURALLY ASPIRATED
4WD
2WD
Sorry if I got some of them wrong by 1 or 2 kw but its what people told me Also tell me if i missed anyone...
Cheers
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
