  • Replies 47
Guys.... as I posted in NSW section the places for this have filled up so unless you have confirmation from me then there's no more positions. I have given a cutoff date for pullouts as next Monday so if anyone does pull out I will let you guys know ASAP.
These are the SA attendees:
JiMBO (R33 Skyline GTS-T)
Soopamarcus (R33 Skyline GTS-T)
Majanal (R33 Skyline GTS-T)
trza2k (S15 200SX)
trza2k's friend (R32 Skyline GTS-T)
Xrsist @ SA (R33 Skyline GTS-T)
Cheers
Originally posted by 400HP
Hi guys,
I've organised a Dyno Day for some friends of mine that will be held at C&V. Currently we have 20 cars and we are looking for another 5 cars.
If we get 25 cars the cost of each car is only $40. This includes 2 passes with printouts (you can run two setups obviously like low boost or high).
The dyno at C&V is a Dyno Dynamix so you can run 4WD, RWD or FWD.
This is probably the cheapest dyno you'll ever do..... however, I am only looking for 5 cars so first in first serve.
Cheers
400HP, What time do we have to be there.
Anyone got the address?
DYNO DAY DETAILS
Date: Saturday 17th August
Place: 34-36 O'Dea Ave Waterloo (call me if you need directions).
Time: Con has stated that cars should be at the venue no later than 9am (PM me if this is a problem). However you may have the opportunity to run your car till later. I think it will most likely be first come first serve unless you arrange with me beforehand.
Cost: $40 (please bring $50 because if lots of people pull out it will be this much. Sorry about that but I think we'll have fill ins on the day anyway).
C&V's TERMS (which they have stated to me verbally.. but these are pretty standard and quite acceptable terms)
- All cars are to be parked at the workshop outside.
- Please do not enter the workshop and walk around because there are other customer's cars there.
- DO NOT enter the Dyno area unless you are given permission to do so as it is dangerous.
- When its your cars turn to dyno your car will be driven into the workshop by a C&V staff and the dyno run will be run by C&V staff.
- No responsibility will be taken by any of the C&V crew on damage to cats which could occur on the dyno (now this relates to engine and mechanical failures.... obviously if C&V do not strap your car down properly or do something which is obviously their fault they are probably liable...)
NOTES
Could these people please let me know their time preferences...
AND if they are content to do just 1 run.... you can do 1 or 2 but please only do 2 if you are going to change something... all 25 or so cars will do one run before anyone does their second run.
trza2k (S15 200SX)
trza2k's friend #1 (R32 Skyline GTS-T)
trza2k's friend #2 (R33 Skyline GTS-T)
Xrsist (R33 Skyline GTS-T)
Thanks
400HP,
I would like to do two runs, one at a low boost setting and one at high boost to measure the differences in air fuel ratio's.
I may have a problem though as the tyres that I have orded have not arrived yet. Do C&V have any problems with tyres with very little tred?
Please call me on 0414 940 938 if there is any difficulties. otherwise I'll see you on Saturday.
Cheers,
Dan.
Well, I'm home.
Had a good day and was plesently supprised at the out put of my car. Was also good news to find out that my air/fuel ratios are good.
Must take this opportunity to thank Yang for organising it all. Good job mate, the day ran really smoothly.
Was good to catch up with some people that I haven't seen in a while, and some that I saw recently. Also good to meet some new people as well.
Run of the day has to go to pete in the barina!
Take care all,
Dan.
Guys.... thanks for coming. It ended up being a great day with a good mix of cars. Here are the results which I have split into interesting categories.
OVERALL POWER
Nick RH9 (R33 Skyline GTR, Highly modified) 290kw @ all 4 wheels
Andrew (R33 GTS-T, Highly modified) 263kw @ rw
NICOT (E36 M3 Convertible) 157kw @ rw without exhaust, 173kw @ rw with exhaust
BLOWN3 (Turbo 318is) 170kw @ rw
Majanal (R33 Skyline GTS-T) 162kw @ rw with 0.9 bar, 141kw @ rw with 0.55 bar
SERGE (E36 M3) 153kw @rw
Yang (Skyline GTR) 150kw @ all 4 wheels
Scott (S14 200SX) 141kw @ rw
Xrsist (R33 Skyline GTS-T) 140kw @ rw
Roland (Porsche Boxster-S) 140kw @ rw
Joe (R32 Skyline GTS-T) 130kw @ rw
Marcus (R33 Skyline GTS-T) 130kw @ rw
Andrew (S14 200SX) 130kw @ rw
Henry (R33 Skyline GTS-T) 127kw @ rw
Daniel (S15 200SX) 120kw @ rw
RONIN (Turbo MR2) 115kw @ rw
Ken/Kelvin (Supra SZ) 108kw @ rw
2FLYBY (Alpina 2.7L) 103kw @ rw
Bob (Mercedes ML320) 101 kw @ all 4 wheels
Rob (MY01 WRX) 100kw @ all 4 wheels
M PWR (635csi) 95kw @ rw
Marcus' friend (Integra Type-R) 85kw @ rw
StygiaN (MR Lancer) 62kw @ rw
ULTIM8DTM5 (Corsa) 45kw @ rw
TURBO
NATURALLY ASPIRATED
4WD
2WD
Sorry if I got some of them wrong by 1 or 2 kw but its what people told me Also tell me if i missed anyone...
Cheers
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
